Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 02-18-2007, 03:42 PM   #15
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Malcolm:
PL 300 is made by HENKEL, a very large chemical company out of Ohio.
It's sold at every HOME DEPOT store (and everywhere else) in Canada so it should be available at your big box stores too.
About $4 or $5 a caulking-gun tube.
Contractors use it to glue all types of foam board to pretty wel anything.
I used it while insulating the trailer.
I don't know why I didn't add a layer of bubble foil to the wheel wells. I have lots of it left over from insulating the walls.
Maybe I'll lift the top off and add a layer. It's only a few screws and rivets.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 02-19-2007, 06:05 AM   #16
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Hi Malcom; 3M 5200 is available in any boat store. It is a permanent adhesive sealant. It is watertight bonds just about to anything. Fast Cure cures in 24 hours. It is a one part polyurethane but it is not recommended for bonding windows. Try 3M Marine Products. Thanks "Boatdoc".
boatdoc is offline   Reply With Quote
Old 02-19-2007, 08:46 AM   #17
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
foam
hi all- interesting thread, I have to do something along these lines next summer. Tell me again please, what are the drawbacks to completely covering the underside of the plywood with foam sheets- filling the entire space between the ribs/joists? And then covering that with foil-bubble, both for added r-value, and protection/containment of the foam? Just thinking out loud here, wanting the best durable r-value as a lot of cold seems to come from the floor. Does the foam NOT create the desireable air-space for the foil? Thanks- tim
tphan is offline   Reply With Quote
Old 02-19-2007, 09:00 AM   #18
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Malcolm, I traced all of the wire in the camper and posted it in my Full Monty thread, in case you need it. I suspect that my 27' and your 31' use the same wiring bundle: http://www.airforums.com/forum...7-post360.html
Great news! The drug companies are now using graphics in their ED drug ads (not kidding). I guess not everybody fully understands what ED is and how to cope, eh?
www.nesa.org
Air No. 6427
Old 02-19-2007, 06:33 PM   #19
Profile:  1973 31' Sovereign
Portland , Oregon
I think that an air gap next to the foil is what helps the foil do the best job. Foam right next to the foil might not be as good as air next to the foil as far as blocking the flow of radiant energy. It is also my belief that if you put a layer of foil below the bottom of your floor by an inch or two that you don't really need the foam too. For that matter it seems to me that you could use the foam by itself and not really need the foil. The foam board that I have seem at Home Depot and Lowes has a plastic vapor barrier on it that might be enough protection. I have also seen some polyisocyanurate foam (at Home Depot I think) That has a foil skin on it.
Personally I would put just the foil under the floor and figure out some way to suspend it a bit below the bottom of the floor such as suggested above using something like strips of foam around the edges of each cavity.
Malcolm
malconium is offline   Reply With Quote
Old 02-19-2007, 06:45 PM   #20
Portland , Oregon
Thanks for the tip. It does look like it might be different than mine, though, at least some. I see in my service manual that the 27 wiring schematic is about the same as a rear bath 31'. Mine is a side bath 31'. Is your 27' indeed a rear bath model?
Malcolm
Old 02-19-2007, 06:49 PM   #21
Portland , Oregon
Down the middle of the ceiling...
I see that I did forget to mention that I have not done anything with insulation down the center part of the ceiling. I thought I would wait until I get all of my wires all sorted out and tucked back into place before I add insulation up there. I am also thinking about what I might want to do differently with lighting down the center. It might be nice to install small halogen lights down the middle. I have replaced all 3 of my fan/lights with Fantastic fans which do not have lights on them so I need to do something different. I have also wondered if it might make sense to do something with 12volt rope lighting.
Anyone have thoughts on this?
Malcolm
Old 02-27-2007, 08:56 PM   #22
Portland , Oregon
Red felt as a thermal break?
I was able to put in some time working on my AS yesterday. I put part of the streetside inner skins back in place. There are 3 rows high on each side with the bottom part coming up to the bottom of the windows, the middle part basically between the windows and the upper part going from above the windows over to the side of the center channel area. I put in the two rows that end at the top of the window.
One of the things that I decided to try was to find something that I could use as a thermal break between the aluminum of the inner skin and the aluminum of the body ribs. I explored various alternatives and finally settled on using strips of regular craft felt. I was able to buy polyester craft felt at a yardage store. The material comes 72" wide. The regular price was $4.99 per yard but I had a 40% off coupon and ended up- buying two yards for $5.99 (no sales tax here in Oregon). For some reason the red felt looked a little thicker to me - or was it just that I liked the color? It looks like that will be enough to cover all of the body ribs. I cut it into strips about 1" wide using my wifes rotary cutter which really works great for the purpose. I then glued the strips on with a thin bead of the same construction adhesive that I was using to attach the foam strips as mentioned above. My initial concern was that it might be hard to find the attachment holes with them all covered up by the felt. That actually did not turn out to be a problem for the two rows that I installed. Once I had a panel located with a couple of screws at the ends I was easily able to find rivet holes with an awl.
I don't know for sure how good of a job the felt will do as a thermal break but my thought was that something was a lot better than nothing. Also I did not want to use something that was too thick and/or too sqaushy.
One thing I remembered to do before putting the skins back on was to take some photographs of what things looked like under the skin. Actually the red felt helps highlight in the photo where the ribs are. I will attach a representative photo below. I think that I may have take this particular photo before I had all of the felt in place. There is a place that looks like it should have some and doesn't.
I started to try re-installing the third row but had to give up for the time being. I have to think about how best to proceed. This piece is about 22' long and maybe 3' wide. It is also much harder to align with the mounting holes than the others. The bottom row and center row was pretty easy with just a little help from my wife to hold one end in place while I attached the other end. Not so with this third row piece! It has to bend more to fit the curve and needs to be held in place above our heads. When we gave it a try I was having trouble finding alignment holes visually through the felt so that I could get things started. I am contemplating needing to cut the panel into 2 or 3 pieces just so that it is light enough to deal with. I can visualize how to splice them back together in places that will be behind cabinets so maybe that will be worth a try.
Anyone have any tricks on how to re-attach that panel?
Malcolm
Old 02-28-2007, 05:18 AM   #23
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
make a couple of T racks out of scrap 2x4's cut one the height you need and another the width, nail or screw them together.
Thats the way sheet rock is done.
Also insulate that access door, just glue a piece of foil to it.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI 11411 | Metro NY | AIR 15915
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 02-28-2007, 09:33 AM   #24
Malcolm,
We had to knock together a kind of scaffold to get the long, wavy 22’ centre panel re-installed in the ceiling. It didn’t take long to make or do.
Like Bob says, they use similar methods to get drywall up.
You will probably need 3 or 4 braces but with this method you and your wife should be able to get the panel up.
It’s better than cutting. If you cut you’ll have to overlap and then be short. It will look better too.
Sergei
Old 02-28-2007, 09:50 AM   #25
Profile:  , Minnesota
Images: 55
I used a T to put the ceiling panel back in my '59. It's a little awkward working alone but you can do it.
If your ceiling panel is as wide as mine, be sure you lay some 2x4s on the floor to protect your toes in case the sheet slides off. The edge of the sheet could slice right through your foot!
There's a fine line between a hobby and a mental illness.
Old 02-28-2007, 10:12 AM   #26
bit off the main topic but
Markdoane,
a little bit off the main topic but can you explain the difference between an "attached image" and an "attached thumbnail" please?
Sergei
Old 02-28-2007, 10:23 AM   #27
Images: 55
Originally Posted by SmokelessJoe
Markdoane,
Sergei
Yeah. The forum software is screwy. Beyond that I dj e hssye skmmau owg?
Old 02-28-2007, 10:49 AM   #28
Portland , Oregon
You really do have a large top panel! Your might be easier in some ways though because of the natural droop caused by lifting it in the center.
Malcolm
Pingbacks are On
Finally, got started ~ 53flyingcloud Cleaning, Stripping & Polishing 506 06-24-2008 12:57 PM
Backing up - Tip & tricks LI Pets Towing, Tow Vehicles & Hitches 44 10-13-2006 11:10 AM
New Owner Questions Hol & Lols 2006 Bambi - all models 49 08-10-2006 07:47 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
SEO by vBSEO 3.1.0
