Old 09-28-2015, 04:51 PM   #1
1970 27' Overlander
Lake Worth , Florida
Floor Storage?
Anyone done/seen floor storage in an airstream? Was thinking about building out some trap door style compartments while I have the subfloor up. They would be relatively shallow, but could definitely use that extra storage space.
helluva is offline   Reply With Quote
Old 09-28-2015, 05:04 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have thought about that but was nervous about cutting into the floor without knowing what actually was under the spot. Doing it with floor already pulled would be easy.
MICHAEL
Old 09-28-2015, 05:11 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Good idea with 'access' you currently have. . be SURE you have it 'watertight' from beneath and above... and have a plan for repair when /if a problem develops.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 12:23 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I thought about doing it, but figured I had enough regular storage. A hidden gun safe was one consideration. However, one thing I did do though when I was underneath was install several "T" nuts in strategic places under the twin beds. This allowed me to run the battery strap and also to screw down my fresh water tank. I have a couple extra in case I needed to strap something else down. I thought about some boat rings too for strapping down a bike or kayak inside, but we're going with more of a museum restoration, and I didn't want anything visible like that. It is nice though about the heavy battery and full water tank. I won't have to worry about a big bump in the road pulling out the little screws they originally used. I would consider a a sealed flashed pan that drops into the space.
The only issue would be near the outside walls where the frame gets strength from the plywood. See if you can add a strip of steel that bridges or frames in your cuttout from below if possible.
the other thing I did was back in the back where i had a rear tank, there was a missing cross piece compared to the rest of the trailer. Meaning, the tank took the place of one of the side to side frame members. As a result, standing in front of the toilet, the floor flexed a little. So, I got a section of steel "L" channel, and bolted it from below. That was the equivalent of moving my missing steel support to the top instead of the bottom. It's right behind the rear bench. So, a little bit better than Airstream's original design. Not sure what you have in your model. I also walked along the floor and used self tapping screws for any soft spots or squeeks. Just used a forstener bit, recess a tiny, put in the screw, then bondo over it. Made my floor more stable.
Just some things to think about while you have the floor available.
robwok is offline   Reply With Quote
Leak at rear bumper storage rotted floor inside A W Warn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 53 10-29-2017 05:27 AM
Does your under Sofa storage drawer fall out on the floor?? ROBERT CROSS Cabinets, Counter Tops & Furnishings 4 04-11-2016 03:02 PM
Wet floor in '86 25' Soverign curbside storage compartment Ssmookler Repairing/Replacing Floor &/or Frame 0 10-19-2014 03:20 PM
Rotten floor in storage compartment marchesi Repairing/Replacing Floor &/or Frame 5 10-04-2014 09:48 PM
"PVC" Styled Sewer Storage/Rear Bumper Storage Repair Frank&Mike Bumpers & Bumper Storage 5 11-04-2010 08:30 PM
