Old 02-13-2004, 01:36 AM   #1
1986 32' Excella
vledder , drenthe
Images: 8
floor seats and curtains
almost finished on the front end now
seats 7 to 8
only need fold down table to make it into a bed
electric floor heating works great no more cold feet
Remco
remcolent is offline   Reply With Quote
Old 02-13-2004, 01:39 AM   #2
1986 32' Excella
vledder , drenthe
Images: 8
front wrap around bench
one more pic
Old 02-13-2004, 05:06 AM   #3
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Well done
Very nice job
muddy_hollow is offline   Reply With Quote
Old 02-13-2004, 05:31 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Thumbs up Lotsa room
Me likey
SMily
smily is offline   Reply With Quote
Old 02-13-2004, 05:37 AM   #5
Very, Very nice.
Dick
Navigator is offline   Reply With Quote
Old 02-13-2004, 10:31 PM   #6
qqq
qqq's Avatar
Thumbs up
Nice layout, & I like the floor... do you have any pics before? also what is electric floor heating?
Hart
qqq is offline   Reply With Quote
Old 02-14-2004, 01:52 AM   #7
1986 32' Excella
vledder , drenthe
Images: 8
thanks
electric floor heating is a 1 mm thin sheet with electric heating element in there
iy warms the floor til about 30 degrees celcius
no more cold feet
Remco
Old 02-14-2004, 08:11 AM   #8
BOBHASTINGS's Avatar
2006 28' Classic
Cincinnati , Ohio
Images: 12
electric radiant under floor heating
Hi Hart,
Radiant heat not only warms the floor - it also supplements the heating of the room itself. Here's a link to a radiant floor supplier, Warmly Yours (corny name, huh!). Very nice site. Warmly Yours Radiant Floor Heat
I put down electric under floor heating in my home bathroom. Very easy - no fancy wiring and you can buy a thermostat to control the temp of the floor. Be aware that most manufacturers only make products to go under tile or stone. Only a few - like Warmly Yours - are for use under wood floors.
I actually used the Easy Heat brand because the product was a single wire that you lay down in a serpentine pattern and I was installing a stone tile floor in an irregularly shaped room. The room is only 5'x8'. The under floor heat is the primary heating for the entire room - no baseboard or forced air heating in the room. (I am just finishing the installation so I can't verify that the room will be toasty to 40 below but, hey, this is Cincinnati, not Nome!!!)
The other style is a thin rectagular or square mat, like what Remco described, that is put down under the floor in one piece. YOU CANNOT CUT THE MAT because you would end up cutting the embedded heating element. That's not such a big deal if you can find a size that will cover most of the floor. I think that Lowes and Home Depot sell the mat style.
I'm not certain if the electric radiant heat would also work on DC current. No reason why it would not work but you'd have to check the current load - might require a 27 bank battery pack to get you through the night!!!
Regards,
Bob Hastings
'06 Classic 28'
'04 Ford F250 V8
Remember :
Happiness is not a station you arrive at, but a manner of traveling.
Margaret Lee Runbeck
BOBHASTINGS is offline   Reply With Quote
Old 02-14-2004, 11:36 AM   #9
qqq
qqq's Avatar
Bob,
Wow...that sure was detailed explanations, thanks,
Hart
Old 02-18-2004, 08:04 PM   #10
69Ambassador's Avatar
1969 29' Ambassador
Tucson , Arizona
Images: 16
Very Inspiring! I'm in the process of restoring my 69 Ambassador and was trying to figure how to work a layout for the front so that the 12 yr old and 7 year old coud sleep in the front without complaining. What sort of framing did you use for the structural peices? I'm always concerned about weight.
69Ambassador is offline   Reply With Quote
