Old 12-25-2006, 11:54 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Fix when cold or warm?
I spent a night in Bessie last week. She has a crack in the end cap up front. The temperature was about 30 degrees when we got there and the crack was about 1/4 inches wide. After warming her up, it shrunk a bit. I've ordered Por 2 part epoxy to fill the crack, but am wondering if I should fill it when she's cold or warm. Any advise? Thanks in advance.....
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-25-2006, 01:04 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It would seem to me that you should epoxy it cold so that when it warms, it would compress. If you were to fill the crack warm, when it got cold, it might pull the crack open again.
SuEllyn & Brian McCabe
Old 12-25-2006, 01:12 PM   #3
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Epoxy cures exothermic. It may not generate enough heat to cure in lower temperatures. The good news is that it will cure once it has warmed sufficiently. Trick is to keep it from running out while you wait for it to cure.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 12-25-2006, 01:38 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Becky,
A couple of things to do, first is to drill a small hole at the end of the crack to keep it from spreading, two is to reinforce the back of the crack with something prior to repair. IIRC the endcaps in our units are fiberglass, the best repair would be from the back side using an 'glass repair kit with the mesh. I am not familiar with the POR epoxy so I can't say what it will or won't do. Good Luck and lets us know how you make out on it...pictures are always nice
Aaron
WBCCI #XXXX AIR #2495
Old 12-25-2006, 04:07 PM   #5
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
What size hole should I drill, and how do I access the backside in order to reinforce?
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-25-2006, 05:30 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The size of the hole depends on the size of the crack, but a 1/8" hole should be enough.
Old 12-25-2006, 06:06 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Good question, peegreen, how do you access the back? Also, I thought the endcaps in a 1976 are plastic & not fiberglass (I thought I read that in previous threads). Would fiberglass bond with plastic?
Becky
1964 Bambi II
1988 Avion 32S
Old 12-25-2006, 06:50 PM   #8
Janets Husband's Avatar
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Take a very close look at it, you will probably see the weave of the glass mat. I believe it should be fiberglass. Yes fiberglass resins will bond with most plastics. I have reinforced a A/C cover for my roof and also fixed the Fresh Water Filler with it, works great. Don't use casting resin, you know the type people put on tables and the like. It is not suitable for this purpose. The issue of temperature, you should always follow the instructions on the material you are using, the manufacturer should know how to use there product. As for the expansion I think you pretty mush up to the whims of the material used originally. I don't think it would matter that much, but you pay your money and take your chances. Of course it would be best if it were at a constant room temperature. However, it will be exposed to freezing and extreme heat in the normal life span of the product.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-25-2006, 07:52 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
to access the back side you will have to take it down...or at least partially down, the good news is I think they went in after the aluminum panels so they should be the first piece to come out... The hole size is not too important as long as it is a tad wider than the crack itself. IIRC I was out of 1/8" bits at the time and was using something around #36 which would be close to a 7/64" I certainly would not want to go any larger than the 1/8"
Aaron
Old 12-25-2006, 08:04 PM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Drill the ends and put something flexable on or in the crack.
Putting something hard in it when it is open will stress the metal. THis will cause the crack to get bigger.
Clear or grey silicone would be my choice.
Michelle TAC MT-0
Sarah, Snowball
Old 12-26-2006, 05:30 PM   #11
Becky B.'s Avatar
1964 17' Bambi II
The PO put silicone in the crack and it doesn't look too great. The crack is open again, but has been drilled on the end. I'm not sure how silicone would look if it's painted over. I know I read a previous thread that said Por 2-part epoxy worked well and could be sanded and painted. What metal will be stressed if I use epoxy? I wouldn't want to make things worse.
Becky
1964 Bambi II
1988 Avion 32S
Old 12-26-2006, 05:32 PM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Becky,
No metal...I think Michelle thought you were talking about a metal endcap not one of the interior fiberglass ones .
Aaron
Old 12-26-2006, 07:53 PM   #13
Keymar , Maryland
Yeah that what I thought. Outside. Inside, fiberglass. I would stop drill it and use fiberglass resin and mat.
Michelle TAC MT-0
Sarah, Snowball
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
