Old 07-06-2016, 01:09 PM   #1
1969 27' Overlander
Hudson , Full-time on the road
Filling small gaps on interior walls
Hi there,
My wife and I are painting the interior of our '69 Overlander. The interior is white and we noticed, even before painting, that there are several small gaps between the metal molding of the walls and the interior skins.
My question is - does anyone recommend a white, flexible product we might put a bead of in these areas to finish the look of the walls?
I've researched quite a bit and Parbond in white is discontinued. If we don't have to paint over a bunch of gray colored sealant, I think that would be ideal.
Anyway - would just a standard latex caulk work or does this need to be something specific? I'd prefer to use a product that will stand the test of time as we travel full-time in this trailer.
Thanks in advance for any guidance!
ID:	266112   Click image for larger version
Wickstrom_A is offline   Reply With Quote
Old 07-06-2016, 01:18 PM   #2
cameront120's Avatar
1972 25' Tradewind
You could try a white latex caulk but keep in mind that the trailer is always moving, so anything you use may not have the desired results for long.
North Vancouver, BC
Old 07-06-2016, 01:35 PM   #3
1969 27' Overlander
Right - I'd rather the product be long-lasting/effective during travel - and be white. Anything that fits those criteria would be perfect!
Old 07-06-2016, 04:07 PM   #4
1974 27' Overlander
Baltimore , Maryland
I used regular white latex painter's caulk for this purpose and painted over it. FWIW that was a few months ago and a couple weeks of actual travel and it's held up fine. Don't know about longer term.
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 07-07-2016, 01:34 PM   #5
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Big Stretch caulking is the answer to your woes. Maybe also get one of those caulk spreaders, or a tongue depressor, to make a nice big sano bead.
Remember that an Airstream flexes quite a bit, both going down the road and when "leveled" in a funky campsite. I tried regular caulking on the edge of my custom bulkhead panels, and it ripped right out.
SuzyHomemakr is offline   Reply With Quote
Old 07-07-2016, 03:44 PM   #6
1980 31' International
1962 19' Globetrotter
Naples , N. Idaho
filling gap between wall and bulkhead
In out 1950 There was a welt like the old vehicles used between body and fender. Has worked out well for 66 years so maybe that is the answer.
yarlj is offline   Reply With Quote
Old 07-07-2016, 04:25 PM   #7
1972 25' Tradewind
Or paint the walls a darker colour and you won't notice the shadow line as much.
North Vancouver, BC
Old 08-09-2016, 04:59 PM   #8
1974 29' Ambassador
La Joya , Texas
Thanks from the tip. I do have a question about what you used on your walls. What type of primer oil, latex or enamel and what paint oil latex or enamel. Thank you!
Lindaboki is offline   Reply With Quote
Gaps in window screens Powerarrangr 2009-2015 Flying Cloud 4 06-29-2016 09:23 AM
Are gaps in the C channel normal in a '57 Overlander? Naddy Repairing/Replacing Floor &/or Frame 13 10-05-2015 08:16 PM
Check your belly pan for gaps! AnnArborBob General Repair Forum 15 09-24-2014 05:43 PM
Filling holes in the walls jolomo Upholstery, Blinds, Walls & Interior Finishes 2 01-23-2009 08:51 PM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
