Old 10-06-2009, 07:06 PM   #15
Ottawa , ON
On my rivet gun, I frequently have to keep pulling the trigger to get the spur to snap off...
Old 10-06-2009, 09:04 PM   #16
I was filling holes today to prep for painting and one of the stems actually got stuck in the pull mechanism in the rivet gun. Wasted a half hour working it out BAH!
Old 10-23-2009, 06:25 PM   #17
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Originally Posted by Roadrunner View Post
After removing our gaucho...I noticed there are now many holes left in the inner skin. There are also holes from PO screws that were removed. We plan on painting the interior. What technique can be used to fill in the rivet holes? Thanks!
Yep to the rivits. Rivits in screw holes tend to stand out a little if you don't peen the old hole. I had some holes I did'nt want to show. For a paint over situation JB weld works well. Just make sure the holes are burr free with a slight countersink, and force enough through the hole for a little "mushroom" effect on the back side. There is also an aluminum body filler out there, can't remember the name. Mixes up like bondo and leaves a finish very close to the aluminum, @ $50.00 per Qt. On a rivit hole in an unpainted interior aluminum skin you would have to look for it. On a polished outside it would show.
putback is offline   Reply With Quote
Old 02-04-2010, 04:26 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Colored Rivets
The interior of my Argosy is white. I found white aluminum rivets at a place called Fastenal. They sell mechanical fasteners.
Old 02-04-2010, 09:18 PM   #19
Ottawa , ON
Jackson Center has them in white, brown, or the "0ff-white" colour on our interior.
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Filling holes in the walls jolomo Upholstery, Blinds, Walls & Interior Finishes 2 01-23-2009 07:51 PM
How to fill old rivet holes tbrom Ribs, Skins & Rivets 5 06-03-2007 10:48 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
