Old 03-24-2013, 05:17 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Fantastic Vent Interior Cover
Has anyone come up with a means of placing a cover over the interior opening of the fantastic vent when it is not being used to block the sun light shinning in. I have thought about cutting some thin material, wood or plastic the size if the outside trim and then painting it to match the ceiling cover. I guess Velcro could be used to hold it in place. Any other suggestions. Thanks
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-24-2013, 05:32 PM   #2
1966 26' Overlander
1995 36' Cutter Bus LE
Largo, Florida , Florida
We had the same problem on our AS Motorhome and purchased a miniature evenshade which was attached to one side and a hook on the other side which you could hook and un-hook at will.--About 10 minutes to install. I think it was made by by Camco. Made to fit 14" openings
brodjeaw is offline   Reply With Quote
Old 03-25-2013, 05:29 AM   #3
adonh's Avatar
1976 31' Sovereign
Sounds good where did you get this from, thanks
Don Hardman
1976 31' Sovereign
Old 03-25-2013, 06:32 AM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Those vents would look so cool with built in blue LED lights. Does anyone make a kit for them?
Silverflames is offline   Reply With Quote
Old 03-25-2013, 10:46 AM   #5
1966 26' Overlander
Camco Mfg. Name of product is "Lights Out Shade" made by Camco-------see above website. Probably bought from Camper World but can't remember. Camco products are readily available from any RV Supplier. Good luck
Old 03-25-2013, 11:11 AM   #6
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Lights Out Vent Shade - Camco RV 42913 - Fan and Vent Accessories - Camping World
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 03-25-2013, 03:55 PM   #7
adonh's Avatar
1976 31' Sovereign
Originally Posted by daveswenson View Post
brodjeaw Camco Mfg. Name of product is "Lights Out Shade" made by Camco-------see above website. Probably bought from Camper World but can't remember. Camco products are readily available from any RV Supplier. Good luck
I found them at PPL RV parts in Houston and bought 2. They should work perfect. I will put them up tomorrow.
Don Hardman
1976 31' Sovereign
