Old 11-01-2005, 01:24 PM   #1
1996 28' Excella
Manchaca , Texas
falling ceiling , 96 Excella
The foam backed , vinyl ceiling strips are coming loose and hanging down . Airstream Tech said to glue back with 3M #70 spray adhesive , which I did twice . The panels came loose again after 2-3 days . Need advice on a cure .
mauser1 is offline   Reply With Quote
Old 11-01-2005, 01:31 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. If the ceiling strips are the ones I am thinking of, you will probably have to replace them with new. The foam deteriorates, and crumbles, leaving the glue holding nothing but, well, crumbled foam. This is a not uncommon problem with autos here in the far southern South, and the only "permanent" fix is to replace the bad pieces. I say "permanent" in quotes because it will probably happen again in 10-12 years. Also, make sure you spray both the ceiling, and the foam, and let both parts dry before sticking them back together.
Old 11-01-2005, 03:07 PM   #3
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet
Mauser1,
Try this thread ... good information:
http://www.airforums.com/forum...lla-14989.html
I also live deep in the far-southern-south like Terry!
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 11-01-2005, 04:54 PM   #4
Well Preserved
1993 21' Sovereign
Another thought-
If you are willing to do this, you can clean all the old foam and vinyl off with a wire brush. Then go to a auto interior shop, and get a sufficient length of automotive headline material. They make an ivory color, and a beige color, and may make white now, too. Cut it to fit the panel, and spray the contact adhesive on the panel and the material. After it dries, apply the material to the panel. After it sets up for a few minutes, re-install the panel. It will not be vinyl like your original, and I have never done it, but it should look good, and is pretty inexpensive.
If you do this, please post photos, so we can all see how it looks when complete.
Old 05-03-2007, 08:32 AM   #5
1996 28' Excella
Springfield , Missouri
I too have the problem of a falling celing on my 96 Excella. I e-mailed the factory tech and the reply was to use 3M Super 77 multipurpose adhesive, found at Lowes, Home Depot, etc. I used that and it is far better than any other adhesive I bought at Wal-mart. I then went to Lowes and bought 3/4 " crystal white batten strips, a Stanley electric staple/nail gun and used that to install the batten strips on the ceiling. I used the 1/2 " nails which worked great going into the aluminum inner skin. I do have a problem with the heads pulling through the batten because the heads are not big enough and the batten is too soft. I would like to find a stiffer batten. The strips were mounted on each side 2 ft. from the center line and anouther row of batten strips 1 ft. past that. E-mail me for pictures.
dbartels is offline   Reply With Quote
Old 05-04-2007, 10:31 AM   #6
The problem is the original adhesive has failed. Applying new adhesive is a waste of time, and money. It may hold for a short time, but when warm weather hits the trailer, the covering will once again come loose.
The fix.
Remove all the wall covering.
Remove "ALL" of the old adhesive from the interior shell.
Install new wall coverings.
Anything short of that is a waste of time.
However, some owners have installed washer type screws, in a pattern to hold the original wall covering in place.
The original adhesive failed because it was another "water base" requirement from our Fed's.
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Help find the weight of a 1981 31foot Excella Sharon Lee Our Community 8 06-18-2002 08:55 PM
