Old 04-18-2016, 11:03 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Extrusion Inserts - Fast and Easy
Let's face it...vintage trailers present with similar challenges. While replacing the bath in the kids "74" Tradewind most all of the extrusion inserts were dry, discolored, brittle and broken. I suppose replacements can be found online; however, one fast and easy solution is to pick up vinyl hanging blind replacements at one of the box stores. The blinds are made of vinyl and can be cut to size very easily...they can also be painted for a unique look. You will find stickum tape on the extrusion once the insert is pealed off. This does not need to be removed...save yourself some time. Cut vinyl to size and insert into the extrusion. Good luck!
Bob "Roadrunner"
Indiana, PA
TAC PA-5
WBCCI 4871
ID:	260944   Click image for larger version
ID:	260946   Click image for larger version
Roadrunner is offline   Reply With Quote
Suitable belt and lower trim molding inserts dznf0g General Repair Forum 11 12-04-2017 12:32 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
stripe and trim inserts ALANSD Clearcoat, Exterior Paint & Trim 13 08-01-2006 11:05 AM
