Old 06-20-2011, 11:03 PM   #1
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Excessive stress on cabinent doors?
On our last outing, my better half let the mirrored cabinent door swing down as I took cover thinking chards of glass would be eminent .
Luckily everthing was fine or so I thought. After the unpack I noticed the door frame had a crack where the two pieces come together. I thought the force of slamming it closed had caused this so I had it fixed and all is well except the other side has the same problem. Im wondering if the spring supports that hold the door open have too much force in opening and closing causing this joint to fail? Has anyonelse seen this problem on theirs? I notice that it actually splits the wood so its visible on the outside. The picture on the top right is the one I just had fixed. Its nice and straight without joint failure.
So what do you think?
1. Reposition the struts so they are located on the verticle slats eliminating the stress on the joint? The downside is that the doors wont open as much.
2. Create some kind of metal support on the back side with screws to help that weak joint stay together when stressing it open and closed.
3. A different kind of strut that is easier to overcome down force?
Here are some pictures to better explain.
Thanks Vinnie
ID:	132940   Click image for larger version
Name:	airstream cabinents 002.jpg
Name:	airstream cabinents 004.jpg
ID:	132942   Click image for larger version
Name:	airstream cabinents 005.jpg
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 06-21-2011, 12:03 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I think that you might want to reglue the joint, if possible, clamp it back together, and add a metal backer to spread the force out. That should fix it forever.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-21-2011, 05:13 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Vinnie,
As Robert mentioned, I think the consensus will be....you need to do a number two with glue.
Bob.
Now I'm out to look at ours....
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 06-21-2011, 07:29 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
What they said, Vinnie. Glue and clamp it.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-21-2011, 08:12 AM   #5
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks guys,
Do you think glue alone will hold it? If I was to add a metal strap would I then mount the strut directly to that? Would love to know if anyone has had this issue or is it just my luck.
Vinnie
Old 06-21-2011, 08:35 AM   #6
2004 30' Classic Slideout
Kerrville , Texas
Mirrored door separation
I had the same problem with the two doors over the queen bed in our 2004 s/o.
I took the doors off so I could work on them easily and applied glue in the cracks and clamped over night. Than added bronze angle brackets and reinstalled the doors. Been fine since than.
Richg
richg is offline   Reply With Quote
Old 06-21-2011, 02:59 PM   #7
Vinnie,
Went out and looked at ours. Exact same style door, hinge and support bracket, but no sign of separation. The way the support spans the crack I wonder if that may have contributed to the brake, uneven surface and/or screws not tightened the same.
Probably best to take the door off, glue and clamp. You'll have to be sure that the screw holes still match the bracket. Make sure the attachment point is perfectly flat and the support will not stress the repair when tightened. If both the door and support bracket match well a secondary support may not be needed.
I could see the same thing happening to ours if the bracket was not aligned or tightened correctly, and you know as well as I, they were installed with a Tesla powered screw driver.
W. H. Auden
Amanamus
"Tahawus"
Old 06-21-2011, 03:12 PM   #8
VIKING's Avatar
Boulder Creek , California
The corner joints on those doors run the wrong way for maximum strength. It would have been much stronger if the vertical stiles ran the height of the door and the horizontal rails ran between them.
The bracket on the back of the break will make them very strong. I wouldn't rely on glue alone to hold these if the wood itself broke. The glue will probably hold but the wood next to it will give out.
Best to you Vinnie!
Rich the Viking
VIKING is offline   Reply With Quote
Old 06-26-2011, 09:46 PM   #9
moderator
Airslide's Avatar
Wilton , California
Images: 50
Here's the solution. Ace hardware had these goodies for about $3.00 bucks..
Now when I open and close the doors there is no more creaking and it fits flush up against the cabinent when closed.
Vinnie
ID:	133414   Click image for larger version
Sealing battery boxes and doors Eugiepayset Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-21-2011 06:39 PM
Spiral thing for Tambour doors rverforlife Cabinets, Counter Tops & Furnishings 12 06-13-2011 12:14 PM
1977 overlander, refrig doors stream lady Refrigerators 2 06-03-2011 04:57 PM
Rebuilding Cabinet Doors webspinner Cabinets, Counter Tops & Furnishings 14 03-28-2011 10:29 PM
Want to replace kitchen tambour doors Gkiesel Cabinets, Counter Tops & Furnishings 0 03-13-2011 06:33 PM
