Old 12-07-2014, 10:53 PM   #1
1968 24' Tradewind
Carlsbad , California
End cap support, '68 Tradewind
I've recently acquired a 1968 Tradewind 24T and am in the process of gutting it to start remodeling.
It was the victim of a half-hearted attempt by previous owners and I am going to have to remove essentially everything and start from scratch.
The forward end cap was "butchered" to add a "custom" cabinet. I removed the cabinet this morning expecting to see support ribs that I could attach new aluminum skins to, but it looks like support ribs were not used behind the end-caps.
Any suggestions how to create enough of a stand-off to allow insulation and the attachment of the interior panels? My initial though is to use aluminum square tubing and bend it on a tube-bender to match the arc and then use an adhesive to hold it in place.
Any thoughts or ideas are appreciated.
I will have several more questions as I work through this project since I have a laundry list of items to replace:
  • furnace
  • AC
  • Holding tanks (replacing all of the plumbing and adding grey water tank)
  • Toilet
  • Axles
  • all electrical
  • all appliances
  • basically everything
Thanks in advance for the help,
Steve
shilgemann is offline   Reply With Quote
Old 12-08-2014, 07:50 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
End Caps are all self supported with no internal structure. Check out the thread below for info on making an aluminum endcap.
http://www.airforums.com/forums/f46/...ed-102982.html
Old 12-08-2014, 08:14 AM   #3
1968 24' Tradewind
Much easier solution than what I was planning. Thanks for posting the link.
Gaucho plastic support end caps, under sink tambour WANTED threedjane Airstream Classifieds 0 06-05-2014 07:37 AM
Gaucho plastic support end caps, under sink tambour '79 Argosy threedjane Airstream Classifieds 0 01-28-2014 07:11 AM
Can end cap support 15# TV? Suzanne 150 General Interior Topics 6 02-20-2008 12:16 PM
Added Support For Frame Rear End tisaacs Repairing/Replacing Floor &/or Frame 2 09-06-2007 05:17 PM
Cracking end cap 76 Tradewind Siamese66 General Interior Topics 2 10-19-2006 05:27 AM
