Old 08-16-2008, 03:06 PM   #1
2007 25' Safari FB SE
Lake Forest , Illinois
Electrical & Hot Water Switch
We just completed a trip to the Upper Peninsula, Door County and other parts of Michigan and had no mechanical difficulties except for the electrical switch in the bathroom which controls the water heater and bathroom light. Everytime we turned it on (either the light or heater) the other lights in the trailer dimmed and on 2 occassions the frigerator turned off. I also noticed that the switch for the heater has a light that used to remain on when the heater was opperative---now the light does not remain on even though the water heater is working.Any suggestions on how to investigate? I was going to remove the white face plate around the switch to check the connections but have no idea as to how to remove it. It either snaps off or is glued.
Looking forward to your suggestions.
Allen
woodedareas is offline   Reply With Quote
Old 08-16-2008, 06:08 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It sounds like you have a bad ground, and the other items are grounding the "problem stuff".
Old 08-16-2008, 07:26 PM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
In my trailer the water heater light only stays on until the propane ignites. It then goes off. My WH is propane only - if you have one that runs off of electricity or propane it may be different.
Al - K4GLU is offline   Reply With Quote
Old 08-16-2008, 07:32 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Same here - gas only WH - light comes on when switch is first turned on then goes out when the gas lights off. In the manual it says this is the way it should operate. Don't know about a duel power elec/gas heater.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-16-2008, 10:33 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Allen,
The switch plates in the newer units snap off. Just be careful that you don't break it!
Once inside, you can unscrew each switch individually and gently pull it toward you to investigate the wiring. Sounds like either the switch is mis-wired, or you have a short or grounding problem.
Since Airstream no longer published manuals that contain wiring diagrams and such, your best shot once it is opened is to call A/S customer service and request a wiring diagram for that switch with color codes indicated, or just find someone in JC that can tell you over the phone.
Let us know how you do...................
Old 08-16-2008, 10:46 PM   #6
yakman's Avatar
2007 25' International CCD FB
Gahanna , Ohio
Our WH light only comes on when the unit first heats up. Outside of that with continuous use, the light stays off.
But with the lights dimming etc., it sounds as though there's certainly a problem.
yakman
yakman is offline   Reply With Quote
Old 08-17-2008, 06:47 AM   #7
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
where is this wh light that ya'll are talking about
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Electrical connections getting hot wardster All Argosy Trailers 23 09-25-2007 03:44 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Help Finding battery/electrical switch Sovereign 1979 mstratton Member Introductions 6 07-01-2006 02:28 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Electrical problem - Water pump, vent hood fan & light Rob30044 Electrical - Systems, Generators, Batteries & Solar 5 11-28-2004 02:38 PM
