Old 03-04-2006, 06:40 AM   #15
Craftsman
Guest
Posts: n/a
I keep one of the small oil filled heaters on continously in my 25' Classic. It keeps it nice and warm all Winter. They seemed to me to be the safest since they never get to hot to the touch and no open flames or fumes to worry about.
Old 03-04-2006, 07:02 AM   #16
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We've got a couple of smaller oil filled that helps in our rig.
One warning that we've learned here at the park, though: In really cold weather, don't rely on the electric. The reason is that your black/gray tanks are heated by your propane system. Now, if you turn on the electric, it does ok in the cabin, but it also causes the propane heater thermostat not to switch on. And that, in turn, results in black/gray tanks that become every colder, eventually freezing.
Bottom line: If nighttime temps are bitterly cold, and if daytime temps don't even come out of freezing, it's best to stick with the propane. If, however, you do use the electric for some residual heat, then locate the thing as far from the propane system thermostat as you can.
Lynn
WBCCI 21043
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
