Old 11-30-2010, 02:33 PM   #1
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Electric Mattress Pad
okay friends,
we just replaced the original mattress [yuck] with a memory foam one [part heavy dense foam part memory foam]. what a difference!
btw, it was a snap to 'cut to fit' the foam with a battery powered electric knife. just make sure you unroll the mattress and let it fully expand before you do any cutting.
question - what kind of electric mattress pad would work best when dry camping?
is it even possible to use one while dry camping and not drain the battery?
a year ago we used our propane furnace while dry camping and the propane lasted but the blower drained the battery.
are there 12v pads that would work for us?
we don't go anywhere the temps are way below freezing. we were just camping in mid-AZ and the evening temps got down around 30.
we have used an electric blanket with hook-ups but feel the blanket would drain the battery too fast.
has anyone used one while dry camping?
i saw a 12v system advertised by ElectroWarmth for use in RV and trucks.
any feedback would be greatly appreciated.
[we tried using our dog but she is pretty small and we would have to share her].
thanks
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 11-30-2010, 03:08 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have been happier with electric blankets (still use one) than I have been with electric mattress pads. I found that I still lost a lot of warmth out the covers when using an electric mattress pad requiring heavy covers to stay warm, but an electric blanket keeps me warm without a lot of extra covers (and weight).
A Google search turned up lots of 12 volt electric blankets.
Vaughan
Old 11-30-2010, 03:19 PM   #3
Central , Mississippi
We put a memory foam mattress in our trailer just prior to doing a western trip in late AUG/SEPT...the bed is so warm we never ran the heater and even left the windows open several nights. It was down in the low 30's several times during the trip.
Try it out one night, I'd bet that with some blankets you will find out you don't need an electric pad!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-30-2010, 03:35 PM   #4
1976 25' Caravanner
Campton , New Hampshire
The 12v mattress warmer works great . Turn it on just before bedtime , jump into warm bed , turn it off , with proper covers body heat will take over . Electric blankets waste too much heat into the atmosphere for dry camping , thus using more battery power.
ticki2 is offline   Reply With Quote
Old 11-30-2010, 03:46 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Agree on the memory foam, you sink down into it, which keeps more of your body insulated and self heating. You don't need any other mechanical method to keep warm. I tried one and found it TOO warm for here in southern coastal VA. Now up in the mountains maybe.
An ordinary foam mattress is warmer than any innerspring - especially the crappy ones Airstream is using now.
I'm a fan of "down alternative" quilts if you need more than a blanket or lightly quilted bedspread. Even if you pay top dollar for eider, tiny bits of featherlets eventually make it outside of the fabric and it's a mess that tracks all over your whole Airstream in minutes.
Foiled Again is online now   Reply With Quote
Old 11-30-2010, 04:39 PM   #6
Images: 20
thanks to all for the info.
so - you only need to run the pad for a little while and then turn it off?
will the heating effect last 6-8 hours?
sounds like you can get away with using it while dry camping. yes?
i really don't want to drain the battery on a cold night.
our 22' AS ccd has both a regular electric plug near the bed and what appears to be a 12v socket similar to the lighter socket found in cars.
do your pads plug directly into the wall plug and come with a 12v converter?
thanks
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 11-30-2010, 04:53 PM   #7
2004 30' Classic
Hillsborough , New Jersey
I would limit the use of any electric mattress pads because of electromagnetic radiation that is given off by the electricity flowing near your body. You are getting "zapped" constantly because you are right on top of or underneath the wires. If you must use them use them to heat the bed and then shut off when sleeping ( Make sure your pet doesn't pee on the blanket, it could cause a fire.)
I can't see that a 12 volt pad can give much heat over a large bed.
Power ( watts) = current ( amps) squared times the resistance (ohms). The more the current the more the heat and the faster you would drain the battery especially if you are heating a large area.
wolf146 is offline   Reply With Quote
Old 11-30-2010, 05:19 PM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I would suggest a nice down comforter. It is chilly when you first jump in, but then body heat takes over, and it is a very pleasant nights sleep. You have the added benefit of not draining your batteries. I know a toasty bed is nice, but I have been comfortable under down when I could see my breath in the room.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-30-2010, 06:26 PM   #9
funkill's Avatar
reno , NV
Images: 27
Originally Posted by az-streamer View Post
...[we tried using our dog but she is pretty small and we would have to share her].
thanks
I find that TWO dogs do the trick. Especially the 80 lb greyhound! No drain on the battery...
Laura
funkill is offline   Reply With Quote
Old 11-30-2010, 06:37 PM   #10
San Luis Obispo , California
I agree with Aviator...I just bought a new down comforter after considering that or an electric blanket...one night in and im not regretting it yet.
I have yet to turn on the furnace, so it takes a lot of willpower to leave the bed in the morning...
joelreh is offline   Reply With Quote
Old 11-30-2010, 06:43 PM   #11
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used an electric mattress pad while boondocking in winter. We had a generator, though. I had never used an electric mattress pad before & I nearly cooked myself alive! I woke up absolutely cooking & had to fluff my bed for a while because it was so HOT! (the pads came with our trailer from the PO). I prefer an electric blanket (if you have to have a preference). At least you can hang your leg out or toss it off of you!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-30-2010, 07:04 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Hey you two! We recently got a memory foam topper for our mattress and we are liking it a lot. It does seem warmer, too...body heat really makes it warm. When camping with shore power we use a small ceramic electric heater set really low to keep the Bambi warm, but it is on very low...and when we are dry camping we use a small propane catalytic heater to warm up the trailer before going to bed, then turn it off...and then fire it up in the AM to take the chill off...works for us... Haven't even thought about an electric mattress pad or blanket... I usually get too warm before I get too cold. In fact, we usually have a vent open to bring in some nice fresh, cool air...even in the winter...
TB & Greg and Abbey Schnauzer
#3954
TBRich is online now   Reply With Quote
Old 11-30-2010, 08:35 PM   #13
Laura
"Three Dog Night" took their name from Australian natives who described the coldness of evening weather by the number of dogs it took to keep them warm... A three dog night equals extreme cold.
Paula
Old 11-30-2010, 08:58 PM   #14
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
If anybody is looking for a foam bed you might try IKEA. We bought one there and really like it. We took the cover off and cut the foam to match the curves in our A/S. It was fairly inexpensive. Also, if you have a pacemaker or ICD watch those electric blankets. Electrical current can effect them. It might end up being a "shocking" experience!!!
mhilley is offline   Reply With Quote
Futon Mattress to Replace Front? Gaucho Bed Mattress? lanajane General Interior Topics 8 05-26-2016 04:07 PM
Comfortable Sleeping - bed, mattress, pad??? kudzu Community Polls 19 07-23-2006 07:31 AM
Ever use a foam mattress pad? drboyd Upholstery, Blinds, Walls & Interior Finishes 13 02-12-2004 04:30 PM
Buying mattress pad? beware of Camping World false ad. femuse Our Community 5 03-19-2003 06:55 PM
Jack Pad JPAIRSTREAM Our Community 0 12-09-2002 06:28 PM
