Old 06-24-2014, 10:19 PM   #1
Wildwash's Avatar
2000 25' Excella
Costa Mesa , California
Easy to get to storage
We have a 25' 2000 Excella. There is plenty of storage space. The problem is that some of it is not that easy to get to. I noticed that in the newer models they make better use of the empty vertical space in the bed room. This was an easy solution. I have not decided if I want to add a matching door over the top 3 shelves.
Name:	ImageUploadedByAirstream Forums1403669953.254276.jpg
Name:	ImageUploadedByAirstream Forums1403669920.185611.jpg
AKA Steve
Wildwash is offline   Reply With Quote
Old 06-25-2014, 07:38 AM   #2
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Something to ponder…Re: adding doors:
What you created is very similar to what we did in the existing wardrobes in our LY. We added shelves & totes. The doors were already in place. Using your picture as a reference, the hinges are on the right side, handle on the left, and the door opens against the wall. Our doors cannot fully open as they hit the window valances. It's hard to tell from your picture, but it looks like you might have the same situation with a door stopping at/hitting the black thing on the wall. The real problem with the door not fully opening, is, the totes can't be pulled all the way out….making the contents more difficult to access. You mentioned easy to get to storage…so, I thought I'd give a "heads-up" on what you might encounter if adding a door. BTW, our "solutions" was smaller totes that can be easily removed. They don't fit the space as perfectly, as yours do…but the space around them is still good storage.
In rereading this, I guess the hinge could go on the other side….or top or bottom…or a fabric roller shade…or. There's probably someone on the forum who has figured this out.
Schools Out is offline   Reply With Quote
Old 06-25-2014, 09:59 PM   #3
Wildwash's Avatar
2000 25' Excella
I'm glad you commented on this. I forgot that I need 100% clearance around the frames. I'll mock this up before I do something lame. The blank thing on the wall is a clock held in place by Velcro.
Thanks again,
AKA Steve
Old 07-09-2014, 01:03 PM   #4
Wildwash's Avatar
2000 25' Excella
The unfinished look did not look right. Added a door. Much better.
AKA Steve
Old 07-09-2014, 03:28 PM   #5
Rockford , Michigan
Images: 12
Very nice!
"PVC" Styled Sewer Storage/Rear Bumper Storage Repair Frank&Mike Bumpers & Bumper Storage 5 11-04-2010 08:30 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Accidents-Airstreams...no easy fix Kistler Our Community 20 09-11-2003 04:41 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
