Old 04-13-2014, 08:40 AM   #1
1973 25' Tradewind
Beautiful , Oregon
Easy Slide Gaucho Make a good idea better
Hi Folks
Could anyone share some good ideas (with pictures even better) on how to build a gaucho that slides easy and is light. Below shows a couple picture I took of my computer screen watching a video on a super easy sliding gaucho. It had 500lbs rated slides. Great job of a 63 renovation. The link to the video itself is below
I bought a couple pairs of the above slides and got a schooling on how heavy they were 8.5 lbs each. I donít want to add 34 lbs in the slides themselves. So I am looking for alternatives. It is going into a 73 TW, front but that shouldn't matter
My original Gaucho bound up a bit and had to rock/pull back and forth to pull out. I know wax etc will improve that but any slick builds out there.
I would love to see tried and true old school examples and some new idea that is doing the trick. Just don't want it to be a chore converting the bed to sofa and back.
Also the video mentioned it pulled out and dropped into notch. I donít know how that would work with ball bearing slides. I plan to drop a pin/ lag bolt in a hole on each side to hold in place. In open position and closed position.
Any help would be appreciated
Tony
ID:	209580   Click image for larger version
Tony S is offline   Reply With Quote
Old 04-13-2014, 07:57 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
There's always wood slides.
Search for Woodworking Supplies at Woodcraft.com
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 04-13-2014, 08:03 PM   #3
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
We made ours using load-rated drawer slides. I did not weigh them, but they were far lighter than the ones you mentioned. They are excellent and gaucho works perfectly. You can see hot is etc in our thread about making our 86 Excella 32 into a bunkhouse with a second bedroom.
Skatiero is offline   Reply With Quote
Old 04-14-2014, 01:15 AM   #4
1973 25' Tradewind
Beautiful , Oregon
The wood slides are interesting
Thanks.
Attached are the monster slides I have been talking about.
Tony
ID:	209664   Click image for larger version
Flooring idea, will this work better than plywood? CampUnger Repairing/Replacing Floor &/or Frame 12 05-17-2012 02:37 PM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Things to have to make sewer issues easy LI Pets Waste Systems, Tanks & Totes 10 12-08-2006 03:23 PM
