Old 05-15-2016, 08:24 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Dust Dust Dust
Just returned from several days in our 71 Tradewind off paved roads in flour dust conditions. There is a fine coating of dust throughout the trailer and closets. Under these conditions it is probably impossible to completely eliminate dust in the coach, but I am looking for suggestions to minimize it. I have the following thoughts:
1. Dust is entering through the vent in the belly pan under the refrigerator. Temporarily seal off this vent while traveling in dusty road conditions.
2. Dust entering through doors and windows. Change gaskets.
3. Dust entering through gaps around wheel wells and belly pan. Caulk and use foam in a can.
4. Use roof fans to blow air into trailer while traveling, pressurizing the coach to reduce dust infiltrating the nooks and crannies.
Thanks.
Old 05-15-2016, 08:41 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out the Burning Man threads and web site for other creative methods.
MICHAEL
Old 05-15-2016, 08:58 AM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
I assume dust at Burning Man is primarily blowing dust. The dust condition I am referring to is dust from towing on severely dusty dirt roads.
Old 05-16-2016, 05:46 AM   #4
AWCHIEF's Avatar
Images: 33
Silly me I assumed the result would be the same. A trailer full of dust.
MICHAEL
Old 05-16-2016, 05:53 AM   #5
Lily&Me's Avatar
Normal , Illinois
Once dust is inside....I find that microfiber cloths do a good job of removing it from surfaces, including ceilings and walls.
Maggie
Lily&Me is online now   Reply With Quote
Old 05-16-2016, 06:57 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Dust is dust. Doesn't matter if it's kicked up by wind or thrown up by tires.
Dust is dry particulate matter ranging in size from 50 to 10 microns, meaning that individual dust particles are too small to see with the human eye. Airborne dust looks like a cloud of dirty air and it's pervasive; it can get in anywhere that air can. You can see piles of dust or a film of dust, but not individual dust particles. Any cloth (or a HEPA vacuum filter) that has openings smaller than 10 microns (microfiber) can pick up dry dust. Anything with larger opening sizes will just stir it up.
Wet dust is easier to pick up than dry dust. This is where Lemon Pledge comes into its own. Spraying the dusty surfaces coats the dust particles and makes them bigger, as well as making the dust particles stickier so that you don't need microfiber to pick up the dust.
The only way to block dust from getting into your trailer in the first place is to seal every opening where air can get inó including your roof vent. Or to avoid parts of the country where you can encounter airborne dust.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-16-2016, 08:06 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
The only way to block dust from getting into your trailer in the first place is to seal every opening where air can get in— including your roof vent. Or to avoid parts of the country where you can encounter airborne dust.
Dust is dust but the condition I am talking about is thick clouds of dust kicked up by towing, thicker at the ground, otherwise no dust conditions. Here in the southwest to avoiding parts of the country where dust is encountered is tantamount to avoiding some of the best camping and just about all boondocking. Dust is ubiquitous but surely someone out there has specific suggestions about what has worked, at least partially, for sealing up a 40 something year old trailer.
Old 05-16-2016, 08:12 AM   #8
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Try useing duct tape to seal over every possible crack.
kscherzi is offline   Reply With Quote
Old 05-16-2016, 08:21 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Being I'm still towing without an interior, I found the biggest culprit to be the wheel wells. I thinned down some sealant and poured it in the gap between the wheel well and exterior skin. This helped the most, new seals on windows and door finished it off. I'm good now.
Old 05-16-2016, 08:35 AM   #10
Lily&Me's Avatar
Normal , Illinois
You can buy a dark colored, flexible, foam type sealer strip for gaps around doors that might work to poke into interior areas....can then be removed and replaced as they get filthy with dust, which they will.
Maggie
1964 Bambi II bearing dust cap louie 1964 Bambi II 1 06-08-2007 11:18 PM
How to remove wheel bearing dust covers ldetsf Axles 12 11-08-2006 01:39 AM
Bearing dust covers Cochese Axles 1 07-18-2006 04:16 PM
Dust Off dustyrhodes General Interior Topics 3 01-27-2006 04:23 PM
Aluminum dust 48_liner General Repair Forum 2 12-27-2005 10:00 AM
