Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 04-28-2009, 04:34 PM   #1
Foiled Again's Avatar
Virginia Beach , Virginia
Dropping my Drawers!
So, ever come back from a trip to find your silverware or undies scattered all over the interior of your Airstream because your drawer flew open - or even launched across a room? I have. The problem seems to be worse in the Safari's than the Classics or CCD's
I just invented a simple stupid fix that leaves no permanent marks on the exterior of the cabinets.
I have the 2006 25 FB SE safari with the handles that will catch your belt loops... which was what gave me the idea in the first place.
I just took a piece of 1 inch black elastic about 8 inches long - burned the ends so they wouldn't run - removed the drawer - and screwed both ends into the back side of the front cabinet frame... behind the drawer. When the drawer is reinserted this loop hangs down slightly into the drawer. When I get underway, I'll pull the loop out over the drawer pulls, where the protruding ends will hold it in place. If the drawer comes open it won't be more than an inch or two, and the elastic will pull it back. Works for the pantry and the closet too.
The overhead lockers? Well that is a different story. Those curved doors on the Safari (Flying Cloud) are actually extruded FOAM core... real wimpy. I'm thinking of putting small cup hooks into the top and bottom frames of the overhead cabinets, then using a piece of elastic with grommets in either end to hook over the cup hooks. This elastic will run out the top of the cabinet (with the hook on the inside of the top frame, then down the front of the closed door, and I think the second hook will have to be under the bottom of the base of the cabinet. Saw what happened to Thecatsandi's interior when the cop hit her!
Paula
The "Girl Tool Kit" strikes again! And you laughed at my high heel and kitchen knife! Ha!
Oh if you have the older style "droopy" television mount, I fixed that too. I just glued a small piece of 1/4 inch plywood under the ball to hold it level. The weight of the TV itself will actually pinch it in place, the glue could be vied as optional.
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 04-28-2009, 06:30 PM   #2
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Hey Paula,
Sounds like some great ideas...Let us know the long term success.
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Yikes Our Drawers Ejected! campadk 2007 Bambi all models 19 10-22-2007 10:50 AM
Will be dropping off my Minuet... wardster All Argosy Trailers 3 12-03-2006 08:54 PM
Help Dropping the Belly Frostyone Repairing/Replacing Floor &/or Frame 0 05-14-2006 11:12 AM
Looking for '64 Plastic Drawers InsideOut Parts Archive 8 11-08-2003 10:27 PM
storage drawers on 345 howardann Exterior Storage Compartments & Access Doors 2 11-17-2002 05:27 PM
