Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-01-2014, 10:02 PM   #1
Anchorage , Alaska
Cader strip canoe building technics for a wood interior ?
I am wondering if the technics used in building a cedar strip canoe, could be used to build up a wood interior?
Seems that the series of horizontal lines coming up from the floor to a "waistline", meeting a series of front-to-back lines along the ceiling and down the sides, would both contribute to the illusion of wider and longer than it actually us. Maybe the opportunity to include some inlays.
If its water tight enough for a boat, would certainly address condensation between the skins
Not sure how the cedar strips would be attached, but it seems with the aluminum ribs, one would have as much to work with as a boat builder.
Has anybody posted pic's of something like this ?
Aktundra is offline   Reply With Quote
Old 06-01-2014, 10:41 PM   #2
Southwestern , Ohio
That would look nice. It's probably do-able, but it would be tricky. When you build a strip-planked canoe you are bending the strips over the outside of the ribs where in the Airstream you would be bending them to the inside of the ribs.
One time I daydreamed of building a cold-molded Airstream-shaped shell from epoxy-glued strips using an actual Airstream shell as the mold. Finished bright it would look quite striking.
I was going to call it a "Woodwind".
Nuvite-F is offline   Reply With Quote
Old 06-01-2014, 10:43 PM   #3
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Would the Woodwind wood wind in the wind in the wind in a wood?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-02-2014, 03:39 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Runaround Sue: 1961 Airstream Safari Ready To Roll! | New Prairie Construction , check this one out!
mayco is offline   Reply With Quote
Old 06-02-2014, 07:50 AM   #5
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I've thought about this as well and decided it would be too challenging to do on a large scale, at least for me. I've built a few cedar strip canoes, and the cedar is largely just a form to shape a fiberglass hull. As a woodworker, I figured I could probably get the cedar strips installed. It would be very time consuming to do right, but laying the fiberglass on the inside, compound curves would be extremely difficult.
Someday, I may try the cedar strip technique on some smaller components.
Thalweg is offline   Reply With Quote
Does anybody know what model this is? johnmccarthy 1954 - 1959 Overlander 2 11-08-2013 08:37 AM
Does anybody know what model of AC I might have kpicard Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-06-2011 10:50 AM
Does anybody know how to find a new key??? camperlola Full-Timing 2 05-06-2010 09:16 AM
Does Anybody Really Know What Time It Is... Kevin245 Off Topic Forum 15 11-24-2009 04:35 PM
Does anybody know where I can replace a rear cover for 1968 Sovereign? tvadman1963 Exterior Storage Compartments & Access Doors 42 10-11-2008 08:34 AM
