Old 10-18-2006, 07:26 PM   #1
1965 26' Overlander
gravel switch , Kentucky
DIY channel 1970 overlander renovation
the DIY channel commenced a 10 episode series on the renovation of a 1970 overlander. the series started on october 7 and i believe 3 episodes have already run. content can be accessed at diynetwork.com and if you search for DCLR-201 you will access the first episode. others can be searched in order from DCLR-202 through DCLR-210. am currently starting a renovation of my 1965 overlander and have found the referenced web site and the series helpful. regards, dave
65overlander is offline   Reply With Quote
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
1966 Overlander International Double Tamara 1965 - 1969 Overlander 30 03-28-2006 02:55 PM
1960 Overlander 66TradeWind 1960 - 1964 Overlander 2 10-23-2002 09:27 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
