Old 04-23-2012, 02:39 PM   #1
The Real Chief Ding Dong
missyloopy's Avatar
1966 28' Ambassador
Patterson , Louisiana
DIY bunkbed
We have a Double bed in our Ambassador and needed a little more room for the children so with a little planning we made something that functions, doesn't have to be stored, Is lightweight, and is not an eyesore.
the double bed mattress is a single bed that slides out and a 1 ft mattress fills in the gap, it sits against the wall. over that the bunk hangs from the wall hooks and covers over the small piece of the double bed mattress. During the day, it functions as a sofa, at night, it becomes a small child's bunk over a double bed.
ID:	156601   Click image for larger version
ID:	156603   Click image for larger version
In love with my Airstream
Melissa Dudoussat
1966 Ambassador Twin (Special Order)
missyloopy is offline   Reply With Quote
Old 04-23-2012, 02:59 PM   #2
Skatiero's Avatar
1989 29' Excella
Marietta , Georgia
Brilliant!!! I love it!!!
Skatiero is offline   Reply With Quote
Old 04-23-2012, 03:14 PM   #3
Ottawa , Ontario
You aren't worried about children falling off the bunk? I would be tempted to put some kind of fence, even a low one, to try and hold them in...
Stay Calm. Be Brave. Wait for the Signs.
Old 04-23-2012, 03:18 PM   #4
Chief Ding Dong
dino242's Avatar
1966 28' Ambassador
They will only do that once. Lesson learned after that
Hee hee.
dino242 is offline   Reply With Quote
Old 04-23-2012, 04:54 PM   #5
missyloopy's Avatar
1966 28' Ambassador
If it were only a single below her I would be worried, but it is a double and she is only about two 1/2 feet above that. We did add extra cushion to the front of the bunk and it is hung at a slight angle to make it more difficult for her to roll out of bed.
Melissa Dudoussat
Old 04-23-2012, 06:59 PM   #6
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
On our D I Y bunk we use a large long closet bar to keep the kids from rolling out. It has a bracket on each wall and lifts out nice and easy. Stows just under the lower bed matress when not in use.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 07-10-2012, 07:24 PM   #7
ottawa , Ontario
I was wondering what you used to make the frame of the bunk. 3/4 plywood or did you beef it up at all?
dcsawLoehr is offline   Reply With Quote
Old 07-11-2012, 01:08 PM   #8
missyloopy's Avatar
1966 28' Ambassador
Lightbulb
There is a frame made of 2x2's ( the long one against the wall is a 2x4 for supporting the eyes that slid over the existing wall brackets). Over that is 1/2 inch plywood ( the bed is for a six year old). Over that is a foam mattress cover( four times thick). We added a little extra foam to the front edge to keep her in the bunk. Back and front covered in material and it hangs in sofa position from the eyes. When it is raised the chains go from existing wall hooks to hooks under the front corners of the bunk. Hope that helps.
Melissa Dudoussat
Old 07-15-2012, 05:42 PM   #9
JDP
2012 16' Sport
Littleton , Colorado
I believe there is a product called guard rails or side rails that can be found at medical supply stores. The guard rail is supposed to slide in between the mattress and the plywood (or boxspring) to keep you from falling out of bed. The mattress shown in your photo might be too light, however, to weight down the guardrail and keep it in place.
MattressInsider.com
AirStream RV Mattress Replacements
JDP is offline   Reply With Quote
Old 07-16-2012, 07:54 AM   #10
Aviator's Avatar
1997 34' Limited
South of Atlanta , Georgia
Very cool.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Aviator is offline   Reply With Quote
Old 07-16-2012, 10:13 AM   #11
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
how much weight do you think it will hold? the chains I'm guessing go into a rib on the roof.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-16-2012, 11:10 PM   #12
Chief Ding Dong
dino242's Avatar
1966 28' Ambassador
The chains actually connect to the factory wall plates that the factory bunk beds attach to. On that side of the trailer, they are both attached to the wall. On the other side of the trailer, one is on the wall (shared with the rear bath), the other is on the ceiling. This being an odd (make that, apparent custom ordered) trailer, the "other side" has no sofa or sleeper below it, so we don't have it setup for that side.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
