Old 11-21-2019, 11:35 AM   #1
2019 25' International
Atlanta , Georgia
dinette table leg and wall brackets
We have a 2019 25 ft. RB Senerity. Love it! I've heard that the dinette should be lowered down into the sleeping position when traveling down the road. Table leg folded folded up with dinette table resting on the wooden frame to prevent the leg and wall brackets from becoming loose from road vibration. It's an extra step when preparing the AS to travel. Any comments?
1590Denny is offline   Reply With Quote
Old 11-21-2019, 05:05 PM   #2
Lafitte's Avatar
2019 25' Flying Cloud
Bullard , Texas
no
we leave ours up
cushions/pillows scatter everywhere
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Old 11-21-2019, 06:51 PM   #3
2007 22' International CCD
Originally Posted by Lafitte View Post
no
we leave ours up
I left mine up with a folded piece of carpet under the leg to keep it from gouging the floor while towing.
Now have a power pedestal and abandoned the folding leg and wall bracket.
rmkrum is online now   Reply With Quote
Old 11-21-2019, 08:00 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
30k+ miles towing have never lowered mine. Have never had a problem.
wulfraat is offline   Reply With Quote
Old 11-21-2019, 08:09 PM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We leave ours up as well
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Old 11-21-2019, 09:20 PM   #6
2018 28' Flying Cloud
Fairfield , California
Our table stays up all the time. No problems during travel. I do have a rubber furniture leg carpet protector under the leg to make a larger surface area against the floor. The leg was making an indentation in the flooring material.
StuartsDad is offline   Reply With Quote
Old 11-22-2019, 11:10 AM   #7
2017 27' Flying Cloud
Volente , Texas
I have a 2017 27 for Flying Cloud. My owner's manual says the Following:
"Airstream recommends that, during travel, the table be left in the upright position"
Donutboy is offline   Reply With Quote
Old 11-22-2019, 11:38 AM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
In our trailer, two table wall bracket screws would come loose and extend, which would prevent the lowering of the table.
Finally decided to replace the screws with Olympic rivets, which once shaved and polished with a Dremel, look just like an original buck rivet and solidly hold the table brackets in place, no matter the road vibration.
Wonder why Airstream chose screws instead of rivets for those brackets...
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 11-22-2019, 11:57 AM   #9
2018 25' International
chino hills , California
Poor Design. We also have a 2018 25 foot International serenity FBT We had Ultimate Airstream replace our table with a coring table & telescoping pedestals . Problems when traveling collapsible leg bouncing causing Rippling-floor damage. We had them replace nightstand with Corian, bathroom counter matching the kitchen Corian . Also put in large vessel sink in bathroom, and covered refrigerator with laminate matching cabinets in the International serenity we also replaced all of our lounge cushions. And a new stove and oven set up Eliminating microwave giving a flush counter . We truly have our Airstream dream. Check out Ultimate Airstream Facebook to see many of their projects we can highly recommend them . Give Ian A call.
redhat200 is offline   Reply With Quote
Old 11-22-2019, 12:24 PM   #10
Replacing the damage floor is costly $8000 to $10,000. As I noted in previous text after Ultimate Airstream did Our make over it now is our perfect Airstream . We were also able to sell the microwave, the table and the complete lounge cushions.
We upgraded to all thatís in the previous text and have the most luxurious Airstream we Ever couldíve dreamed.
Old 11-22-2019, 12:40 PM   #11
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I would like to replace the leg and wall mount for our table as it is very shaky when using it.
Anyone have any recommendations on a sturdy table pedestal?
It can be manual or power but overall must be sturdy. Ours gets used as both a table and bed.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-22-2019, 02:59 PM   #12
Hermes's Avatar
Once we replaced the wall bracket screws with Olympic rivets, I drilled a small hole in the front of each wall bracket to screw in a "jam screw" (a short metal screw) which jams the table bracket against the wall bracket and prevents the table from moving or shaking when we use it.
We rarely lower the table (and don't have any floor damage) so I don't need to remove the two jam screws (which only takes a few seconds if necessary).
Old 11-22-2019, 03:42 PM   #13
Look at Marine Supply stores. I think thatís where mine came from.
Old 11-27-2019, 10:42 AM   #14
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
I think these are the one Ultimate Airstream uses, at least for manual ones.
https://www.llebroc.com/product-p/spr-1660230.htm
daleyocum is offline   Reply With Quote
Old 11-27-2019, 12:33 PM   #15
2018 27' Flying Cloud
Rancho Palos Verdes , California
Table travel
We leave ours up. But, as some have noted, the floor began wearing under the leg. We placed a doorknob wall protection plate ( large flat circular stick on ) on the floor and all is well.
lynnand1120 is offline   Reply With Quote
Old 11-27-2019, 01:39 PM   #16
Always learning
1974 27' Overlander
2007 25' Safari FB SE
Woodway , WA
table placement
I keep mine up, but have found that the years of lowering and raising it seems to loosen and weaken them the most. One of the mounts finally gave up the ghost this fall, so i had to buy larger screws and replaced them all, so i should be good for a few more years....
barryz is offline   Reply With Quote
Old 11-27-2019, 05:46 PM   #17
SailAS's Avatar
Sugar Land , Texas
We traveled for years in our 2007 25FB Safari SE with the table up. The only issue I ever noted was the "less than solid" stance when we use the tsble. I cured that by installing a pneumatic tabke pedestal from Springfield. It's the same as used by AS at the factory for the highest trim levels. It's not cheap but resolves the "shaky" feeling. I afixed mine so the wall brackwys engage as well for a backup connection.
SailAS is offline   Reply With Quote
Old 11-27-2019, 05:55 PM   #18
Went with a 12v powered one. Came from the clearance page of a Marine supply store a year or two ago. Has a dome-shaped pedestal that conceals the motor and has limit switches to stop it full up or full down position. A reversing switch with center-off position controls it.
Have added a U-channel to the wall and a nylon roller follower on the tabletop to reduce movement. Holds it solid and straight no matter where I set the height.
Makes it more useful for dining all the way up or set lower to desk height for using my laptop.
Old 11-27-2019, 06:35 PM   #19
2017 19' Flying Cloud
Calgary , Alberta
It should be left up while traveling. We had ours down once while traveling last summer and the catch that locks the leg in the folded position broke. Now the leg does not lock in either the up or folded position. The result is that the table will collapse if the leg is inadvertently bushed, or touched.
Ronyx is offline   Reply With Quote
Old 11-29-2019, 10:14 AM   #20
Smh
2018 27' International
Truckee , California
We leave ours up. We put our entryway mat under the leg when towing to protect the floor.
Smh is offline   Reply With Quote
Adjustable dinette table leg, 1978 Sovereign Hair Goddess Airstream Classifieds 0 04-14-2017 10:17 AM
Need to shorten dinette table leg FCStreamer General Repair Forum 14 07-11-2016 12:45 PM
Curtis Wright dinette table leg chris hart Cabinets, Counter Tops & Furnishings 3 06-07-2015 12:59 PM
Dinette Folding Table Leg Length? jayseejay 2009-2015 Flying Cloud 8 05-18-2015 02:12 PM
