Old 08-15-2016, 11:41 AM   #1
2016 19ft flying cloud
Spokane , Washington
Deep pocket sheets
We are taking delivery on our new 2016 19 ft flying cloud CB tomorrow
Ya
The mattress on the newer models now has a pillow top which makes it 8" high
Anyone out there have any luck locating any fitted sheets that fit?
Airstreams are really expensive and they are back ordered anyway
We have looked on line and everyone just have the old 7 inch ones which aren't going to fit,,,
Ken & Ruth
Spinonedad is offline   Reply With Quote
Old 08-15-2016, 11:59 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Safari came with two sets from these folks. Excellant fit and construction.
http://www.ablifestyles.net/everything-for-airstreams/
MICHAEL
Old 08-15-2016, 01:40 PM   #3
2016 30' Classic
Erie , Colorado
Use regular fitted sheets for the bottom. Example I use twin size deep pocket fitted sheets on my twin bed classic with added topper. It is a bit to wide but doesn't really matter. You can always get the slide on sheet clamps from Bed Bath and Beyond to help keep things in place. Same for the queen bed in our previous FC. Works fine and much less for what ever thread count you want to buy. Also at BBB you can buy individual pieces. I like a full size top sheet rather than a twin.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 08-15-2016, 02:40 PM   #4
Long Island , New York
Ditto to Michael in Post #2. We have a mattress pad and all-cotton sheets from ablifestyles and are very happy with the fit and fabric after a few washings. There are earlier threads on this, which I will post later from home.
Old 08-15-2016, 10:57 PM   #5
The new airstreams have a thicker mattress with a pillow top
We called ABlifestyle ,,they don't have them
Old 08-16-2016, 03:07 AM   #6
Welcome to the forum! [I forgot to say yesterday] And welcome to the introduction to your new project to customize as you wish, when things are not quite up to snuff. For us, hitting little hurdles like this are part of the fun of owning an Airstream! You end up with your trailer.
Did the mfg. give you a lead time?
Here are the earlier threads I mentioned yesterday. There are plenty of ideas for using regular sheets with custom adjustments which are available off-the-shelf apparently.
By using the Search function at the top right [the lower Google box in the drop down menu] for "sheets" here are the search results:
https://cse.google.com/cse?cx=011403...ets&gsc.page=1
. . . and these threads look promising:
http://www.airforums.com/forums/f46/...ets-92677.html
http://www.airforums.com/forums/f514...fb-118732.html
http://www.airforums.com/forums/f312...ts-147433.html
From reading those threads last fall, I seem to recall that either Kmart or Walmart carries "suspenders" you can attach to the sheets under the bottom of the mattress.You might have to use oversized flat sheets for your new larger mattresses?
At this time of year, I would simply grab some sheets that will let you sleep on the bed, and hit the road ASAP! [without fretting over getting it perfect on the first attempt -- ]
Good luck.
And Happy Trails!
Peter
PS -- From this thread, or from any of the others, you can "bounce up" in the organizational structure here [see the blue terms between the ">" symbols at the top left], and click on General Interior Topics, for instance, to see the list of all topics in this sub-forum.
Old 08-16-2016, 03:44 AM   #7
www.streamingairheads.com
streamingairheads's Avatar
Gettysburg , Pennsylvania
I purchased the 8" sheets and blankets for my FC25 Twin from this place as well. They fit great.
streamingairheads is offline   Reply With Quote
Old 08-16-2016, 04:35 AM   #8
skitique's Avatar
1974 Argosy 26
1990 34' Excella
Charleston , South Carolina
Those slid on sheet clamps are great! Didn't know about these until recently
skitique is offline   Reply With Quote
Old 08-16-2016, 07:45 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We got our sheets from a lifestyles. We use a mattress topper so they didn't fit properly. But afterwards I found our that is you tell them the thickness of your mattress they will custom fit it for something like an extra $20.
2012 Dodge Durango Hemi/AWD
Old 08-18-2016, 01:34 PM   #10
Another possible problem from ablifestyles?
[click on arrow in quote to go to that thread]
Originally Posted by OTRA15 View Post
Another thread recently noted a problem with ablifestyles not having sheets for the new thicker mattresses. Maybe someone should ask them if their commitment to Airstream owners is failing?
Hmmmm . . .
http://www.airforums.com/forums/f46/...ts-155291.html
Original post here:
These deep deep scratches.. Stupidnoob Cleaning, Stripping & Polishing 43 05-01-2015 01:07 PM
Pocket door rollers for 67' Safari Adair Cabinets, Counter Tops & Furnishings 3 10-12-2007 09:23 PM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 04:50 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 04:40 PM
