Old 03-14-2013, 08:57 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Day/night shade tension adjustments?
Howdy..
Is there any kind of adjustment for friction on the "day/night" shades? I have one that is not staying where you put it, only leaving it down will it stay.
Thanks in advance... Peace..
Old 03-15-2013, 07:08 AM   #2
Lily&Me's Avatar
Normal , Illinois
If yours are like ours, there is a screw thingy at the bottom on each end, where you can pull and tighten a bit.
Maggie
Lily&Me is online now   Reply With Quote
Old 03-15-2013, 07:49 AM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
These things work on a combination of tension and friction. Examine where the strings exit the bottom of the shades and if the shade is wide, there may be one or more places where the strings loop across and go back up into the shade. If it appears the strings have cut into the guides, you will likely be considering replacing the shade in the future. If you are asking about your '99 model, as I recall they used something that looks like a plastic sewing machine bobbin at the left and right bottom ends of the shade to anchor the strings. Determine if one end is not as tight as the other and either give the slack end an extra wrap around the bobbin, or untie the knot, add tension and retie the knot. The anchor points may be different, but the solution is to add enough tension to the string and try to get the left and right about the same. Don't overdo it. Over time, these strings can break and if the shade is otherwise in good shape, it is possible to restring it but the first one you do can be a real challenge.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 03-15-2013, 08:39 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks folks!
Peace and Blessings..
Channing
WBCCI# 30676
