Old 07-24-2005, 06:46 PM   #1
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Cutting Holes in Aluminum
I will soon be installing some small low-voltage recessed lights in my Airstream. I need to cut small (approx. 2 1/2") holes in the aluminum ceiling for them. Has anyone tried using a hole saw on their coach? Is there a hole saw available for metal (and one that won't tear the vinyl)?
Curt
somefun is offline   Reply With Quote
Old 07-24-2005, 07:17 PM   #2
Craftsman
Guest
Posts: n/a
I would cut the vinyl using a razor knife before cutting with a hole saw.Use a compass to draw the circle,then drill a pilot hole using the same diameter bit as the hole saw , insert the hole saw so the teeth are above the vinyl before starting the cut. I think you may risk ripping the vinyl otherwise. Better safe than sorry.
Old 07-24-2005, 07:21 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Just make certain that the centering drill bit doesn't go thru the outside skin.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-24-2005, 09:37 PM   #4
And keep in mind if lights are on the ceiling - to not cut the electrical wires running fore to aft.
Do a search to find out exactly where the wires are.
If the holes are more to either side, then you only have to be concerned with the individual wires dropping off the center bundle.
Sav'h Steve is offline   Reply With Quote
Old 07-25-2005, 12:29 AM   #5
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
A little trick I use when drilling through material that is finished with a hole saw is to run the hole saw backwards for mabey 5- 10 seconds. This will run the cutting teeth backwards and precut the finish without ripping it when you go forward.
-Tim
theVAP - Airstream Podcast
Old 07-25-2005, 02:58 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Watch out for ribs and wiring! I believe I would rather cut those holes by hand using snips rather than the hole saw...with a bit of practice you can cut them just as neat and just as quick by hand as by using the hole saw...less chance of something going astray and causing damage. Also you are going to have insulation wrapping itself around the pilot bit causing problems.
Aaron
WBCCI #XXXX AIR #2495
Old 07-25-2005, 07:34 AM   #7
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Keep in mind that the bit may wander as the saw's teeth hit the aluminum. You may consider cutting a template for the hole saw out of 1" stock, and have someone firmly hold it up against the ceiling where you want to cut the hole. This might help minimize any wandering and keep your hole centered and true
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
