Old 04-17-2006, 11:55 AM   #1
Lightbulb cushion foam
Does anyone know how you can wash the foam cushions to get a musty smell out of them ? Would regular detergent work ? Then is it possible to dry foam under low heat in a laundromat ? Help please !!!
airtim is offline   Reply With Quote
Old 04-17-2006, 02:18 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
My suggestion would be to replace and not even try to clean them. The cost of good foam is not very much. You can choose the thickness and density. We even have two different densities on the same cushion so it will give support but feel cushy on the tushy. These are on the former sofa each is over 6' long and cost us less than $75.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 04-17-2006, 02:29 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Two questions? Have you gotten the covers off the foam cushions? Is it a dirty, cigarette/smokey smell or moldy/mildew smell?
I ran into a similar situation, I think like all trailer owners, when I first got my GT. I talked to my brother-in-law who is professional antique furniture restorer, repairman. His advice was if there is mold or mildew on a foam cushion, it's in the cushion and needs to be replaced. It's not practical to try to clean them. A larger chain fabric store can get you the correct foam at a reasonable price.
I have taken the covers off the cushions and washed them with good results. The bad foam in the front gaucho, gone.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 04-17-2006, 03:59 PM   #4
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
foam's cheap... everything else is expensive
I concur with these answers. We replaced all the foam in our 1999 AS because of the musty smell. It was only a couple hundred for the couch, a bit less for the dinette.
Unfortunately, we also re-upholstered. The labor wasn't too bad - again a couple of hundred per. But the fabic!!! OMG!!! That was a killer!
Tin Diesel is offline   Reply With Quote
Old 04-17-2006, 08:44 PM   #5
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
A great DIY source of quality foam, cut exactly to size and specification is http://foamsource.com . The are based out of Boulder, CO.
I used them for a reupholster job I did in older trailer with a BAD mildew problem, and I was quite pleased, especially with the custom sizing. Everything fit EXACTLY as expected.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 04-17-2006, 10:11 PM   #6
1960 24' Tradewind
santa barbara , California
Hello airtim,
Yes and yes definately replace the foam or have your cushions completely redone. was in my 60 trdwnd .Nice and new ,clean fresh smell .totally worth it when there all redone and installed ,then you take a lounge on the cushions ,oh yeah !! Many fabrics and retro fabrics available .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 04-18-2006, 04:53 PM   #7
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
An offer
I have two foam back cushions from my former 22' International that are essentially brand new; just the foam with no covers. I replaced them with softer foam when I did some interior work.
Free to anyone in the Austin, Texas area who will pick them up or meet me at a convenient place. I will be glad to measure them for you. Send me a PM if you are interested.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 08:19 AM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 08:39 PM
foam cushion replacement mareinmn Upholstery, Blinds, Walls & Interior Finishes 1 03-11-2003 09:21 AM
Cushion Dimensions, Front Sofa Alan and Julie General Interior Topics 2 08-05-2002 02:14 PM
Where to get new cushions made? Andy R Upholstery, Blinds, Walls & Interior Finishes 8 04-16-2002 01:32 PM
