Old 02-04-2008, 10:11 AM   #1
tkendall's Avatar
1976 31' Sovereign
Anytown USA , The open road.
Cool Cracks in Plastic...How do you repair?
Here is something I need help with. In our 76' Sov, we have the front bulkhead that is made of plastic or something close to it. We have all the plans in the world for indirect lighting, new curtains, and other cool stuff. The clock and thermo. works as well as the roll up doors, but there are cracks in the main body.
Has anyone found a product to fill or repair these cracks? If so, please help with a source.
tkendall is offline   Reply With Quote
Old 02-04-2008, 10:24 AM   #2
Kevin245's Avatar
Mine appear to be plastic as well and are doing the same thing. I think some are/were made of fiberglass too. My plans are to end drill the cracks, abrade the suface then overlay them with fiberglass.
Kevin
Old 02-04-2008, 01:34 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If they are fiberglass, you can drill to stop the cracks, sand, and coat with Tiger Hair, sand smooth, and paint. If you do it right, the trailer will crumble to dust before the 'glass ill need further attention.
Old 02-04-2008, 02:14 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I fixed the bulkhead in my former '76 Overlander. First I drilled the ends of the cracks. Then I used fiberglass to cover the cracks. Then I used bondo over the fiberglass. I sanded between these two steps until the surface was nice and smooth. Then I sanded the entire bulkhead so it was roughed up for painting. I used two coats of white primer and finished it off with two coats of eggshell paint. Turned out pretty nicely.
ID:	53682   Click image for larger version
Name:	ceiling fix 2.jpg
Name:	ceiling fix 3.jpg
ID:	53684   Click image for larger version
Name:	finished ceiling fix.jpg
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-04-2008, 04:27 PM   #5
tkendall's Avatar
1976 31' Sovereign
Thank you all very much
This is what I thought to do, but didn't know if there was any better way. Now for the lower section. Is it fine to do the same there? Thanks.
Genuis has limitations, stupidity has none.
Old 02-04-2008, 04:47 PM   #6
lynn's Avatar
You can order a new one through an Airstream dealer.
lynn is offline   Reply With Quote
Old 02-05-2008, 08:32 AM   #7
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Cracks in plastic end caps
Good to hear how to fix the fiberglass ones but the front and bath plastic type end caps seem to cracking even though I drilled a small hole at each end to help stop the crack. They also seem to be a one piece unit. Has anyone fixed the end caps made of plastic and what did you use as rerinforcement on the curved portions to strengthen them?
1978 Argosy 27 rbt
John
Argy 78 is offline   Reply With Quote
Repairing cracks in plastic interior parts. boatdoc Upholstery, Blinds, Walls & Interior Finishes 18 07-05-2016 07:07 PM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 12:42 PM
Cracks forming on shell --- Repair Help !!! SlammaJamma Ribs, Skins & Rivets 3 05-26-2005 10:22 AM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 08:19 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
