Old 05-30-2008, 05:17 AM   #1
Cracks in end caps?
Okay, here's a subject that comes up from time to time. We now have a couple cracks in the "plastic" end caps of our 29'. Has anyone developed a repair for these when the develop? Thought I'd check before I start messing around with various concoctions.
The cracks are courtesy of some absolutely terrible stretches of interstate I recently was forced to travel.
How about we take a couple Billion out of Iraq-about a weeks worth- and fix our %$#$%^& road systems!!
Anniedog is offline   Reply With Quote
Old 05-30-2008, 08:14 AM   #2
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
The caps can be repaired, but I'm afraid the best looking repair would involve taking the cap out and doing the repair on the rear. Our shower pan (also ABS) had some nasty cracks and we had it repaired with fiberglass on the reverse, then painted with epoxy. A frontal repair may be possible, but it may not be as strong as being able to reinforce the area surrounding the crack on the rear. Regardless, you'll need to paint it to make it look like it was never broken.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 05-30-2008, 09:00 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Before patching drill a hole at the end point of the crack to keep it from running. I have had some success on smaller cracks with using Crazy Glue. I am not sure what material the end caps are made of but I found out the hard way fixing cracks in the ABS bathroom sink counter that ABS does not like polyester resin.
Old 05-30-2008, 10:52 AM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Prehaps you need to consider new axles. If it need to be replaced you will find rivets shearing, panels with wrinkles, and generally the trailer tearing itself apart.
Over59 is offline   Reply With Quote
Old 05-30-2008, 08:57 PM   #5
Question New axles?
Interesting point. Just how would a person know whether new axles were needed. I don't think thats the case for us, but its a good issue to dicuss. I am pretty sure I know how these developed.
Old 05-30-2008, 09:42 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
There's a lot of stuff on diagnosing elderly axles if you do a search. Readers Digest version is the wheels should not ride too high up in the fender well, the torsion arms should not have an upward angle and there are other tell tale signs such as wrinkles and bulges in the shin where they should not be.
Old 05-30-2008, 09:45 PM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Andy says you should be able to see 2-3 "of the top of your tire,any less than that you need new axles.
easyride is offline   Reply With Quote
Old 05-30-2008, 09:48 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Good rule of thiumb. Also if you jack the coach up the axle should drop a couple of inches before the tire leaves the ground.
Old 05-30-2008, 10:00 PM   #9
2010 27' FB Classic
N/A , Texas
Good suggestion. I too had problems with cracking. I was at Jackson center one time and had the end caps replaced at high dollar. Then a few months later I had cracks again everywhere they put in a rivit thru the plastic. So now i just use your method of drilling and glueing. It does not look great but it seems to work. Another thing I was considering after doing repairs that way was to cover the end caps with a material. For example, a thick cloth of some kind that could be glued on in strips. But I have never got up the nerve to try it. If someone was good at wallpapering I think it would work. If someone trys it please let me know how it turned out.
Or, another thought would be use velcro dots to hold the cloth in place. Sort of like a dashboard cover.
2 panel end caps??? byamcaravanner Off Topic Forum 1 02-03-2008 10:34 AM
interior plastic end caps catson4 Interior Restoration Forum 1 01-05-2008 07:30 AM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 08:44 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 05:07 PM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 01:42 PM
