Old 03-28-2012, 08:39 AM   #1
Lily&Me's Avatar
Normal , Illinois
corrosion ? around light fixture?
Discovered this today.
Can anyone tell us just what it is and how to fix and treat it?
Thanks.
Maggie
Old 03-28-2012, 08:50 AM   #2
1965 22' Safari
East Islip , New York
What's the material of the fixture? Stainless or Aluminum?
If it's stainless, that does look like galvanic corrosion. Should clean off with just a scotchbrite pad, but you'll need to put some kind of gasketting between the two if you don't want it to come back.
-Hans
HHaase is offline   Reply With Quote
Old 03-28-2012, 09:34 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
http://www.airforums.com/forums/f142...ml#post1122759
Al - K4GLU is offline   Reply With Quote
Old 03-28-2012, 10:50 AM   #4
Lily&Me's Avatar
Normal , Illinois
-Hans
I think it's stainless. It's on the ceiling of the Interstate, which with the walls all appear to be stainless.
From reading the thread link Al-K4GLU posted, looks like we should treat with WD40, scrub clean and maybe apply a clear coat of some sort before adding a gasket. The corrosion had just started to creep out from under the fixture, which is why we noticed it.
If it's aluminum, should we do something different?
Thanks, all.
Maggie
Old 03-28-2012, 01:22 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Maggie,
Is there any evidence of a water leak there?
I believe both the fixture and ceiling are aluminum and you have a bit of the infamous filiform
Try to get the fixture out as far as possible.
Spray the area of corrosion with wd40 and let it soak in, wipe down with a microfiber cloth. Repeat several times. Take/post another pic so we can see how much has come off. That will help in determining the best way to seal the area.
It looks as though it's extending past the bezel just a little, so it shouldn't be very obvious once it's sealed.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-28-2012, 01:38 PM   #6
Lily&Me's Avatar
Normal , Illinois
I haven't seen evidence of a water leak, but this is near the Fantastic vent that leaked horrifically the first year or so, so that may well have occurred.
We are doing the WD40, some of this stuff seemed rather thick and came off in small sheets, like a scab.
Be back with a picture.
Maggie
Old 03-28-2012, 01:53 PM   #7
Lily&Me's Avatar
Normal , Illinois
This seems to be cleaned down to a rough, rather corroded surface. Should we sand this with something?
BTW, did take a look at that other thread on filiform corrosion. Wondering if it matters that this is inside our unit.
Did find a couple of other small spots within this same fixture, also treated and wiped.
Old 03-28-2012, 02:05 PM   #8
Maggie,
I would wipe down the area with mineral spirits and tape around it with blue painters tape to keep from marking the undamaged area.
Then use a scotchbrite scrubbie with more 40 to see if you can get more of it off. The last operation may be 40 with superfine grit wet/dry sandpaper, but try the scrubbie first.
W. H. Auden
Amanamus
"Tahawus"
Old 03-28-2012, 02:12 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
It sure looks like filiform..."growing" from the raw-cut edge of the aluminum interior skin...just how it appears on the outside of some newer rigs... It's odd to be occurring on the inside ... and to me it indicate that there is/was a leak somewhere that's allowing the are to become moist. I'd treat it with Corrosion-X and Boeshield T-9. It's not likely to remove it, but it will stop it.
TB & Greg and Abbey Schnauzer
#3954
Old 03-28-2012, 02:24 PM   #10
Lily&Me's Avatar
Normal , Illinois
Okay.
We are at Edisto Beach and used borrowed WD40 because ours had dried up.
We will be leaving here Friday morning, will pick up mineral spirits et al and follow the rest of these suggestions. We have clear coat at home and will be there by the end of next week.
Back in a couple of days with a new picture.
Maggie
Old 04-03-2012, 09:34 AM   #11
Lily&Me's Avatar
Normal , Illinois
We have cleaned with mineral spirits and scrubbed with WD40 and Scotchbrite, repeated X2. This is what it looks like at this point. There is one deep spot on the largest area of corrosion. Do we need to use fine sandpaper, as well? One of the holding brackets was rusted and broke, and the entire cut surface for the fixture appears corroded and was treated.
Old 04-03-2012, 09:43 AM   #12
JFScheck's Avatar
Rockville , Maryland
Images: 33
Disimular metal corrosion could be the cause, especially if your Airstream is subject to high humidity.
Have you treated it yet? If so - how?
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-03-2012, 10:13 AM   #13
Doug,
It's really hard to tell from the pic how deep the corrosion is, I've found it best to remove it completely down to the skin. But that's been on exterior panels using a dental scaling tool. From a distance, hard to notice.
But inside, where distance is limited.....
If it were me I would clean the hidden areas further and clear. Wire tooth-brush or fine emery. Then get the smaller visible area as smooth as possible and seal/clear.
The more you disturb the surface the more visible it will become.
Keep a close eye out for further progression, and save any more aggressive action for later if needed. Stainless paint is an option, but not a "perfect" match.
Wish I could be more help.
W. H. Auden
Amanamus
"Tahawus"
Old 04-03-2012, 10:23 AM   #14
tpi
Trabuco Canyon , California
It looks like corrosion brought on by a leak, or at least chronic wetness. It sounds like you have possibly found and repaired the leak.
If it were mine, I'd look for a way to put a gasket between the stainless and the aluminum if possible. I'd also get some ACF 50 and treat the aluminum. Then I'd check it occasionally especially after a rain or humid conditions to see if it is getting wet. Plus reapply the ACF 50 occasionally. Probably WD40 has some ability to inhibit corrosion and you could use that instead as long as you monitor it, and insure it isn't getting worse. Treat not just the corroded area, but all around the round cut.
tpi is offline   Reply With Quote
New LED light kit with sealed lights Dan@LED4RV Commercial Listings 18 08-26-2012 11:18 PM
Tail Light Surround alfaguyair All Argosy Trailers 11 04-21-2012 03:55 PM
Loose Moen galley fixture Goal15 Sinks, Showers & Toilets 9 04-13-2012 12:36 PM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 09:31 AM
Intermittent Under-Cabinet Light - '09 25FB Intl bbherb Lights - Interior & Exterior 2 03-15-2012 07:47 PM
