Old 03-19-2009, 11:33 AM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Combo 12vdc smoke and CO detector
Can anyone point me to where I might find a 12 volt combo smoke/CO detector.
I have search here and the web and only come up with 120 volt or battery operated models.
Your help is much appreciated.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 03-19-2009, 12:50 PM   #2
1963 24' Tradewind
San Diego , California
on line do a search for an RV combo detector. I have a Safe-T-Alert combo propane/CO. It's not a smoke det. You also need a propane det.
Propane and CO Detectors/Alarms, Leak Dectector, Pressure Test Kit
Sixty3TW4US is offline   Reply With Quote
Old 03-19-2009, 02:54 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
You usually want the smoke detector on the ceiling and the propane detector on the floor. I have battery powered a CO detector with a digital readout that I like a lot. My smoke detector has a 10 year battery which is the life of a smoke detector. After 10 years, just replace.
Vaughan
Old 03-19-2009, 04:39 PM   #4
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
10 year battery? I wouldn't mind one like that.
Could you please tell me what model it is.
I have the interior torn out of the trailer and thought I would add wiring for LPG, CO and smoke detectors. I've done the wiring for the LPG detector and thought it would look nicer and be easier to wire if I could find a combo smoke/CO detector.
Bruce,
Old 03-19-2009, 08:45 PM   #5
1983 34' Excella
1967 24' Tradewind
Images: 32
It's a Walmart.com: First Alert 10-Year Tamper-Proof Smoke and Fire Detector: Home Improvement unit that I got at Wally World. Unfortunately the CO detector that I like, a Kidde KN-COPPPD-B has been harder to locate online. I like being able to see levels of CO that thave trigger the detector (if it happens, It has only happened to me as the result of the "Univolt" boiling the battery and off gasing) as well as the levels insufficient to trigger an alarm. Good diaginosing information.
Vaughan
Old 03-19-2009, 09:54 PM   #6
1959 22' Flying Cloud
Escondido , California
Safe-T-Alert Model 35
The Safe-T-Alert model 35 has both a propane and CO detector. It should be out next month.
There is an older model that sells for a little over $100. RVupgrades.com has it. It's their part numbe 66-8836.
Gilbert
"On a vintage Airstream if it aint absolutely broke DON'T TOUCH IT!!"
2bkidfree is offline   Reply With Quote
12v
Smoke Detector alarming with moisture? davidz71 General Interior Topics 1 07-30-2008 08:41 PM
Best Battery operated CO and Smoke Detector RBolton Batteries, Univolts, Converters & Inverters 6 10-16-2007 05:20 PM
Smoke detector Ed L General Appliance Topics 4 05-14-2007 01:58 PM
CO smoke detector questions 63air General Interior Topics 9 04-15-2006 08:31 AM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
