Old 04-13-2006, 02:06 PM   #1
1963 19' Globetrotter
Moline , Illinois
Question CO smoke detector questions
Can anyone out there who is an actual engineering type tell me what the difference is between a battery operated smoke/CO detector used in a residential/ commercial setting (thus sold at at a reasonable price in any home store) and one that is sold with the RV certification at twice the price? Is there any reason a home detectors can not be used in an RV other than a lawyer being involved somewhere in the process. I'm not taking about the 120v 12v hardwire types.
63air is offline   Reply With Quote
Old 04-13-2006, 03:56 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Would you think it might have something to do with sensitivity? Maybe the RV models take a bit more combustion in hand before they go off. Smaller volume to monitor, more a chance of cooking setting them off.......Although we carry a shower cap to put on ours when we start the toaster up.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-13-2006, 04:16 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Jack
Great idea! Now I have a reason to take the free shower cap from the hotel room. I know it's not to keep my hair dry. That went down the drain years ago .
Richard
Old 04-13-2006, 04:23 PM   #4
jcanavera's Avatar
Fenton , Missouri
Images: 143
When ours goes off it causes one of our dogs to go into the shake and cower mode. Even pulling the thing down off the ceiling prior to cooking sends shivers of terror into him. Patty came up with the idea and it really works great. It also gives us a good visual to remember to pull it off when we are done cooking.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-13-2006, 07:06 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
getting back to the original question...
The ones certified for RV use, are supposed to stand up to shock, vibration, and temperature variances better than a home unit.
Old 04-14-2006, 09:00 AM   #6
cammur's Avatar
Roseville , California
The one that came with our 2005 Safari is very sensitive, perhaps again the small space. A slice of unburned toast will set it off. But what it has that I haven't seen elsewhere is a button that cuts the sensitivity for about 2-3 minutes, allowing you to do toast without setting it off. During the interval it emits soft occasional beeps as a reminder that it isn't operating at full sensitivity.
It also has a retaining pin that makes it less likely to be shaken from its mount.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 04-14-2006, 09:48 AM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Yep we have that on ours also. Unfortunately it still sends my old pooch to the nut farm with its warning reminder beeps.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-14-2006, 10:33 PM   #8
cammur's Avatar
Jack
I agree with your pooch. It is less terrible than the full decibel alarm, but still unpleasant.
Cam
2005 25' Safari SS
AIR #8752
Roseville, CA
Old 04-15-2006, 05:39 AM   #9
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Originally Posted by 63air
Can anyone out there who is an actual engineering type tell me what the difference is between a battery operated smoke/CO detector .
I did not know you could get a combo detector. My belief was that the smoke detector was to be mounted in a high spot (smoke rises) and the CO detector in a low spot (gas forms in pockets on the floor.)
When it comes to something as important as a smoke or CO protector I do not question the cost but do as told.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 04-15-2006, 08:31 AM   #10
2002 25' Safari
Dewey , Arizona
Images: 62
Carbon Monoxide is slightly lighter then air. It basicly will mix with the air in a room. Suggested locations are at eye level in a room, but away from (not above) things such as heater ducts and ovens. I have a battery powered combo CO / Smoke unit in my TT. It is not a RV unit, but a first alert household type. We store it with the towels with no power when in travel mode. When we setup it goes on the wall with batteries and is tested. If you press the test button it will go through both systems and give you an audio readout of the highest CO level (PPM) it has read since last tested.
I think you might have CO confused with Propane. Propane is much heavier then air and will pool on the floor. Propane detectors need to be mounted low near the floor.
Richard
Smoke detector Ed L General Appliance Topics 4 05-14-2007 01:58 PM
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
Water Heater black smoke grantb4 Water Heaters, Filters & Pumps 5 11-07-2005 09:18 PM
Dull walls and yellow plastic ends 74SovereignInt. Upholstery, Blinds, Walls & Interior Finishes 35 10-15-2004 12:57 AM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
