I have a 2012 International 25' FB. The pantry is a skinny pull-out to the left of the range and microwave. The pull-out is mounted on "ceiling" and "floor" rails of the compartment. The shelves allow container leaks and debris to fall to the "floor". Cleaning is difficult.
Is there a release for the rails so I can temporarily remove the slideout? So far it looks like I would have to disassemble the entire compartment.
We have the same in our 25FB Classic. There is release on each rail as you pull it out you disconnect the inner rail. If you not sure go to Home Depot or Lowe’s and learn how to release the inner rail. Watch out the pull out is heavy and very awkward to handle. Once out I changed the light weight ones that AS installed to a set from Lowe’s that is rated to 100 lbs.
