Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-23-2004, 06:59 PM   #1
tinsltootsie's Avatar
cleaning interior
It looks like we will be finishing up the plumbing and hopefully other things will go fairly well. If not, I guess for now we can use coolers and outside grills. But I was wondering if anyone had any good ideas for cleaning the plastic and special coating .....also since we will not replace carpeting and cushions yet, how do you get the (smell) out????? I plan to clean well with a carpet cleaner, but i'm not sure if regualr cleaner will do it. Any help would be appreciated. Thanks
Debbie
tinsltootsie is offline   Reply With Quote
Old 06-23-2004, 07:05 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
What year is your trailer? The materials vary from year to year...so the cleaning process may be different.
The only sure way to get rid of the smell is to replace the foam, upholstery & carpet and any 'bad wood' underneath.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-23-2004, 07:32 PM   #3
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
I agree with Shari, the more soft goods you can replace, the better the "trailer smell" will become. I would add this however, after replacing all foam, curtains, upholstery and flooring, we still had a slight odor. I purchased an ozone generator and used that in the trailer on a high setting for two days. It was amazing what a difference it made. The lingering odor disappeared and was replaced with a slight smell of bleach. An occasional touchup with ozone generator keeps the dreaded "trailer smell" from returning.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 06-23-2004, 07:37 PM   #4
gotair's Avatar
Send a message via MSN to gotair Send a message via Yahoo to gotair
whats an ozone generator
Life's short...take your kid camping
gotair is offline   Reply With Quote
Old 06-23-2004, 07:44 PM   #5
1964 26' Overlander
Norman , Oklahoma
Images: 67
Check this web address, it will answer all your questions.
www.air-zone.com
Mark Wilson
Old 06-23-2004, 08:28 PM   #6
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
I'm curious about this air cleaner. Not only does our trailer have an "old" smell, not bad, just something I notice, but I often find a stale smell coming upstairs from our large furnished walkout basement area. If you do not mind sharing the information, which size do you have? How do you use it, in the house and in the trailer? Thanks if you can tell a little more about it.
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-24-2004, 12:03 AM   #7
71_safari's Avatar
West Linn , Oregon
Images: 12
ozone can be harmful
I have asthma and am very sensitive to ozone in any quantity, whether from vehicle smog or ozone generators. Ozone is damaging to the lungs in small quantities, and I for one would not have an ozone generator anywhere near me. Because there are many misleading claims about them, I would suggest you check out the info at the US EPA website before purchasing one.
www.epa.gov/iaq/pubs/ozonegen.html
You'll have to cut and paste that as I forgot how to make it a link.
john
Currently living in SE Asia
1971 Safari 23 (sold)
71_safari is offline   Reply With Quote
Old 06-24-2004, 07:18 AM   #8
I have a 1974 overlander. I do plan to replace all soft goods as soon as possible, but with limited time and good vacation time looming, it may have to wait until fall, or next spring/summer. I am thinking of using my handy dandy carpet cleaner on all carpet and cushions, and adding a touch of bleach..... Any thoughts on this??? I know a little bleach on the curtains didn't bother the fabric, and aided cleaning as well as conquered that odor. The water odor problems are minimal as the only leaks were those due to breaks in water pipes. Those are being dealt with as well as wood which was saturated.
Old 06-24-2004, 07:58 AM   #9
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
My wife was leery of being too harsh on the factory curtains that came with ours. The cushions had the original fabric, too, which we had to jetison after we discovered gnawed areas underneath. She used Woolite on all of the fabrics and they turned out looking sparkling clean and smelling fresh.
John
AYRSTRM2 is offline   Reply With Quote
Old 06-24-2004, 07:34 PM   #10
The curtains seem okay. I used woolite on some, then switched to regular detergent with no known problems....i'm hoping they hang well. I ironed and pleated today, but it is possible that there was some shrinkage. Maybe I will try taking the covers off to wash carefully. Those i am a little more leery of. We seem to be lucky so far with critters and such, but, while things have been gone over fairly well, I will find our more with the final cleaning. I order a new door seal which i hope continues to keep us "critter free".
John
Old 06-24-2004, 07:50 PM   #11
Penguin's Avatar
outside is nice
I put the "soft goods" outside to air several times after we got our Trade Wind. We are very lucky because our rig doesn't have the musty smell, but I am always a proponent of sunshine and fresh air.
A couple of weeks ago, I read on one of the posts that replacing the screening helped with smells! Guess screens would catch lots of stuff that could generate a smell.
Connie
We'd walk all day for a '66 Trade Wind!
Penguin is offline   Reply With Quote
Old 06-24-2004, 10:09 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
Check this out before you wash your upholstery...
Cushions & Fabric
Shari
Old 06-25-2004, 08:23 AM   #13
Send a message via Yahoo to silver suz
The commercial type of ozone generators create lots of ozone for a short time, which reacts with the odors. Then are taken out and the house is aired. These kind of machines are used after fires, mold etc. You might want to try a corona discharge machine rather than and ozone machine. suz
silver suz is offline   Reply With Quote
Old 06-25-2004, 07:56 PM   #14
What? A corona discharge machine? Does it come from Mexico and in a bottle? I guess a few of them would help. Sorry to be flip, but i don't know what you mean. Could you explain?
Old 06-25-2004, 07:58 PM   #15
I loved your pictures and decorating scheme. I am looking forward to getting to that point sometime. Thanks for your info.
Connie
Old 06-25-2004, 08:02 PM   #16
Oops! I think I meant your pictures, which were great! I guess I will just use the rinse and vac on them, instead of trying the washer on delicate. At least then, I can hopefully use them as a pattern when sewing new covers. Thanks. That is something you can't undo.
Cushions & Fabric
Shari
Old 06-27-2004, 10:18 AM   #17
Debbie the newest Gaiam Lifestyle magazine has an article on air and pp104 explains the difference among all the indoor air cleaners suz
Old 06-27-2004, 02:25 PM   #18
Gaiam reference
Thanks, but i don't subscribe to that magazine. Is it available on line?
Old 07-14-2004, 01:36 PM   #19
Sorry I've been gone a couple of weeks. Maybe you could look up www.gaiam.com. silver suz
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 40 05-16-2017 04:58 AM
1970 Sovereign Interior MarkCinCLT General Interior Topics 5 08-15-2004 03:01 PM
Cleaning Interior; No Electric; Inverter ?? Sue&Von General Interior Topics 2 12-16-2003 05:50 AM
Help with Interior Heights? sbernasconi9 Our Community 4 10-27-2002 08:33 PM
