Old 02-20-2014, 01:50 PM   #1
richw46's Avatar
Lexington , Kentucky
Question Cleaning fabric walls
The interior fabric walls of our AS are in pretty good shape but you can tell there has been some light mold. PO said he removed the curtains because of mold, it being easier to care for it without the curtains. He installed blinds.
The lower walls show some staining from the mold. This is the fabric portion, not the vinyl near the ceilings. Is there any way to clean this?
Rich
2006 Safari 75th Anniversary Edition
richw46 is offline   Reply With Quote
Old 02-20-2014, 02:12 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Living in the mold capital of the US doesn't make me an expert on mold, but it gives me plenty of opportunities to experiment. One thing that seems to work relatively well for me is white wine vinegar.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-20-2014, 02:34 PM   #3
1994 30' Excella
Mississauga , Ontario
are you sure it is mold. Often moisture causes the aluminum behind the fur to oxidize. This causes black stains to show on the wall.
Al
Al and Jean
TAC ON-3
Old 02-20-2014, 03:29 PM   #4
richw46's Avatar
Is this a preventative or a cleaner (or both?) ?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Old 02-20-2014, 03:41 PM   #5
Cleaner, mostly. The only real preventatives that work are lots of ventilation and dehumidifying.
WBCCI #1105
TAC LA-4
Old 02-20-2014, 03:46 PM   #6
richw46's Avatar
Al
The wall covering appears to be some kind of fabric. In the areas below a window or above the bed (at the trailer bend) it appears dirty. I'm working around the L-Lounge and areas usually hidden have additional 'dirty areas' so I suspect it was caused by mold.
Here's a photo, I didn't get a close-up but you can see it's fabric and not vinyl.
I'm a newbie, not sure what you mean by fur The wall covering??
-Rich
Rich & Yvonne
2004 4Runner SE
Old 02-20-2014, 06:01 PM   #7
Yep. Full tongue-in-cheek name, "imitation mouse fur."
WBCCI #1105
TAC LA-4
Old 02-20-2014, 06:37 PM   #8
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
What you have (as I do) is a high quality carpet type material.
It's great as it vastly improves the insulating qualities of the interior walls. (sound attenuation is improved as well.
The ceiling material is a Marine grade vinyl.
In most models AS went away from interior fabric to save money after the down turn...BUT also as people did'ent know (or care) how to take care of it....the ceiling can delaminate from the skin and the carpet can develop stains and odors.
The carpet material can be cleaned in several ways.
For isolated stains a little oxyclean and water works.
If you want to do it all you can ...
a)go and rent a carpet cleaner and simply follow the instructions.
b)hire a firm to come in and clean it and it'll come out like new.
It is critical that you keep the interior dry....couple tips.
Boiling, cooking, showering etc....run the fans and open the windows. Dry the shower and dry the towels out side. When sleeping keep a couple windows/vents cracked open as exhaling alone adds moisture to the interior. A little ceramic fan is great to keep things dry (or a little de-humidifier if it's hot out).
Cheers
Del Gurney is offline   Reply With Quote
Old 02-20-2014, 07:15 PM   #9
richw46's Avatar
Cheers
Lots of good information, thanks Del.
The material on the walls can be cleaned like carpet? I guess you use the attachments like you'd clean a chair or couch?
I keep the AS at a storage facility; deed restriction here at the house. I'll have to think of a way to get some circulation going when we aren't using it.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 02-20-2014, 07:54 PM   #10
1994 30' Excella
I always leave the small bathroom fan vent open. As we all know there are numerous holes in the floor from plumbing etc. This allows enough air to vent out of the trailer that I never have condensation issues while in storage.
Al
Al and Jean
TAC ON-3
Old 02-20-2014, 08:01 PM   #11
richw46's Avatar
Al
Thanks, Al. I'm not sure how to leave it open. I'm still very green, we just got it on Saturday. I know there is a vent that comes out the roof, I assumed it worked like the vent at home, by the fan opening the vent. Is there a way to manually open the vent?
-Rich
Rich & Yvonne
2004 4Runner SE
Old 02-20-2014, 08:06 PM   #12
T1NCAN's Avatar
2005 19' Safari
1 , Washington
I too have the same interior. I put a "Dri Z Air" in there when not in use. It helps dehumidify. No issues for me.
T1NCAN is offline   Reply With Quote
Old 02-20-2014, 08:10 PM   #13
1994 30' Excella
Mine is a small round vent. The make is ventline. It has a plastic handle that you push up to open the vent and a switch to turn on the fan. It is about 5 inches in diameter.
Al
Al and Jean
TAC ON-3
Old 02-20-2014, 08:27 PM   #14
mtbguy's Avatar
Dunwoody , Georgia
On my 2008 with the same carpeted walls, I have a few 1 inch diameter black spots where I believe previous owner used a metal dowel rod as a space divider/privacy curtain holder.
I used resolve carpet cleaner on these spots and they seemed to get a little fainter but larger. Now I have 2.5 inch (not quite as dark as before) spots and I think it looks worse.
I may try some oxyclean. If that doesn't work I am toying with the notion of a very small paintbrush and some very delicate touch up with grey water based paint. There is carpet that goes down into the hatches underneath that I can practice on first.
mtbguy is offline   Reply With Quote
New Awning Fabric Installed, Thanks To You! Max Well Awnings 12 04-23-2012 07:15 PM
1969 Safari - cleaning the Interior walls VeggieBullet Upholstery, Blinds, Walls & Interior Finishes 12 10-19-2011 05:05 PM
carefree awning fabric width johnhh Awnings 0 07-30-2011 09:16 AM
grease reapearing on walls? turfclubroad Upholstery, Blinds, Walls & Interior Finishes 6 04-04-2011 09:02 AM
