06-20-2014, 07:10 AM
#21
2022 Atlas
Homosassa
I've thought that some of the dark places were either glue that was too thick from the factory or where the windows have sweated and water ran down. I haven't gotten the places off but they are behind the couch so I haven't been too concerned. I need to try the oxy though.
06-21-2014, 07:27 AM
#22
I'm In
, Kentucky
There is a website for Oxyclean. They have a lot of different products and some suggestions on cleaning. They always say to start in an inconspicuous place :-)
OxiClean - Home Page
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
06-21-2014, 08:11 AM
#23
2007 34' Classic S/O
The Villages
Tried some OxyClean spray
I bought the OxyClean spray yesterday and sprayed it on several spots on the ozite. I scrubbed it with a brush and then rinse/wiped it with a wet towel. The spots are probably 50% or more gone. Definitely faded. I'll give them another treatment today and see how that works out. But it's much better!!
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
06-21-2014, 08:15 AM
#24
The Villages
Those spots are almost certainly caused by the aluminum. It could be a little nick or an unused screw or rivet hole or just a place where the fabric rubs. If you have ever buffed aluminum, you'll see how dirty is is. Abrasions such as grinding is very dusty. I worked in the metal fabrication industry for quite a while and I have seen the mess aluminum can make.
Phil & Doris Drugge
06-23-2014, 08:48 AM
#25
I'm In
, Kentucky
I emailed AS support about the wall covering in my 2006 Safari and got this reply. Instead of 'mouse fur' they refer to it as the 'wall rag'.
[Please see attachment]
-Rich
Rich & Yvonne
06-23-2014, 09:37 AM
#26
2004 34' Classic S/O
Stafford
, Virginia
The spots come from the screws and rivets, and a lot of aluminum shavings that are left behind the wall rug. I just finished replacing most of the wall rug in my camper; I had to work with a vacuum cleaner to clean up all of the aluminum shavings and dust.
The rivets get loose and rub against the aluminum wall, causing black dust to form. The factory tapes over most of the rivets heads on the walls, but not all of them. The tape prevents most of the dust from getting on the wall rug.
The black marks are not just from leaks, as some of the wall rugs I replaced where not near anything that might leak.
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
06-24-2014, 08:05 AM
#27
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
we have had good experience cleaning our mouse fur walls with grocery store grade, foaming, Woolite rug cleaner. and yes, there is one small streak that we've never gotten out, no matter what we've tried. but, it's hidden behind a drape!
"Oxy Clean" is primarily comprised of a DuPont product called Oxone. it is also commonly known as potasssium monopersulfate, or, potassium peroxymonosulfate, or simply, MPS.
you can often find it in bulk (one pound, three pound, five pound, etc.) at a favorable price at a good spa or pool supplier. here in the northeast, for example, we used to buy it at Namco Pools in 5# plastic containers of their product called "Saf-T-Shock."
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
06-26-2014, 08:08 PM
#28
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
Done with the carpet walls
I found the ultimate way to clean the carpet walls in a 98 Safari. I turned them into a CCD model.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
06-26-2014, 08:19 PM
#29
2006 25' Safari
St. Augustine
Well, that is ONE way to deal with it- excellent.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
06-28-2014, 09:20 AM
#30
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
Done with the upgrade and it looks great!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
06-29-2014, 07:13 AM
#31
2023 16' Basecamp
Chgo. N.W. Burb's
Rented the Rug Dr.Pro from Home Depot . Purchased a bottle of the Upholstery Cleaner also..Did the Upholstery and the carpet on walls. Did a Great Job on both. First time in 7 years it was done. Did a pretty good job on those rivet stains. All for about $33 and almost 4 hrs of work.
I think we will use paint to eliminate the rivet stain.
