Old 08-25-2016, 09:59 PM   #15
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
If you clean the skins with acetone, one should not have an issue. I did that and also painted with an aluminum primer with a hitech additive- no issues, great bonding. I also sealed and ran a bead of caulk on all the seams and ribs. I so re-engineered the frame/shell/floor connection. My frame and shell bolt together and the floor is independent. I can remove my floor at anytime without removing the shell. The spray foam in my rebuild for me is the best option for insulation. For other maybe not. I did weigh all the options and this the one I chose. I went with rigid foam board under the floor for insulation. This spray foam technique is an option for those who maybe considering spray foam- mostly those with more time than money😁
Matt
rugjenkins is online now   Reply With Quote
Has anyone ever removed ALL of interior and inner skin to spray foam inuslation? crazeevw Classic Motorhomes 16 11-09-2014 06:47 PM
Spray polyurethane foam insulation sfixx Exterior Restoration Forum 58 05-29-2011 08:45 AM
Update, leaks and spray in foam ugggh!! Bex All Argosy Trailers 13 07-25-2010 07:45 PM
Spray Foam Insulation Question Gkiesel General Repair Forum 3 04-08-2008 01:08 PM
