Old 11-15-2004, 08:08 AM   #1
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Ceiling Panel Removal
I need too remove the panel to find leaks and have had no luck at getting it out.
Can anyone tell me how to remove this panel.
Don
Gunnyusmc is offline   Reply With Quote
Old 11-15-2004, 08:44 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Don
Don,
Are you referring to the center section?
If so go Here. About half way down I posted a step by step how to.
If I am guessing wrong, please let us know
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-15-2004, 06:03 PM   #3
1973 31' Sovereign
Portland , Oregon
Images: 22
It might be in there really tight...
If you are indeed talking about the ceiling panel down the center then, besides all the steps mentioned by Brett, you may just have a really tight panel. I was dismanteling my entire interior and taking off all of the interior skins and had a dificult time getting the center section out. It is supposed to be a slip fit into the metal channels along the edges of the center such that it can be slid out once you have removed the rivits or screws that are holding it in here and there along the middle area. You are supposed to be able to get the center to bow down some so that one edge will pop out. I found that one thing that helped a lot was to squirt some silicon lubricant into the channel area to loosen things up. I must admit, though that I could not get the center panel off all by itself. I had to take one of the side panels next to it off first. I used a putty knife shaped paint scraper to tap the moulding off of the center panel on one side. What I found was that there were some additional thin strips of aluminum that had been jammed into the same track, perhaps to help hold things in tight. It sure worked. I hope that your center panel is a lot easier to get out than mine. At least you should now have enough information to give it a good try. Unless of course you are talking about some other panel.
Malcolm
malconium is offline   Reply With Quote
Old 11-16-2004, 07:14 AM   #4
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Ceiling Panel removal
Malcolm
Thanks Malcolm & Brett.
That is the panel I'm trying too pull, as I am putting a batwing antenna in and want too run the cables out of view.
Don
Panel or not Over59 Ribs, Skins & Rivets 6 10-07-2004 12:20 PM
Fuse panel bluebonnet Electrical - Systems, Generators, Batteries & Solar 7 08-15-2004 10:42 AM
Attempting to access front eyebrow panel Don in E Texas General Interior Topics 4 04-14-2004 08:04 AM
Control panel wanted... Rick Electrical - Systems, Generators, Batteries & Solar 0 09-03-2003 03:40 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
