Old 11-22-2008, 08:47 PM   #1
Lombard , Illinois
Ceiling Fan and Cabinet Molding
I have to replace broken domes on the ceiling fans on my 1976 International. In addition, the forward fan/light combo needs a new fan shroud, and more than likely a new motor....very loud and wobbling. Would I be able to get the domes and shroud, or better off trying to retrofit a newer style fan? The only problem is new fans dont come with a light kit..so Id have to somehow modify. Anybody else have to deal with their fan/vents?
Also, the "t" plastic molding that slips into the grooved edge of all my closets and counters is pulled out and distorted. Anyone know where I can get this product?
Greg
Gregory is offline   Reply With Quote
Old 11-22-2008, 09:46 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
Greg,
Do any of the following links look familiar?
switch
Lens
motor
vent dome
Fan Blade
Your motor may be good, and the blade may be chipped and out of balance.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 11-22-2008, 11:21 PM   #3
Greg
We have all the parts you need, except the "T" molding.
We alsohkave "solar gray" vent covers, that have a thermal barrier and let in far more light than the original white covers, but no more UV.
Old 11-23-2008, 03:30 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Gregory,
Another 70's owner here. Couple of suggestions...you can buy replacement parts, or you can upgrade. I am upgrading my vents to a Fantastic Vent over the front living area, then adding a semi recessed Thin Line fluorescent fixture. Center vent is staying stock, but getting the old automotive style bulbs replaced with fluorescents. (it takes some modifications) The rear vent over the bath area is being replaced with a Maxx Fan. I have most of the bits and pieces but haven't had the time to "git er done"
Aaron
WBCCI #XXXX AIR #2495
automatic ceiling fan problem tinsltootsie Roof Vents, Skylights & Fans 9 07-30-2007 08:44 PM
Ceiling fan be oiled? Dan S All Argosy Trailers 6 07-05-2007 09:53 AM
ceiling vent fan question? wayne.yl Roof Vents, Skylights & Fans 6 06-24-2004 03:49 AM
Ceiling Fan? Fun-Lovin General Interior Topics 6 08-20-2003 08:44 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
