Old 07-01-2015, 05:37 AM   #1
2000 30' Excella
Monticello , Florida
ceiling falling down
What kind of glue is used to hold the header to the aluminum?
The plastic strip that holds the joints together was not properly installed such that it just barely caught the edge of the ceiling panel, so now with the heat 100+ it has fallen down
Iím thinking of using a spare plastic strip that I have and cutting it so that it can be slipped under the one in place to hold the panel up. Perhaps using rivets to hold it in place and painting it.
Any ideas?
07007 is offline   Reply With Quote
Old 07-01-2015, 06:07 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
If it has the vinyl material with the orangish foam backing, the issue is that the vinyl separates from the backing and falls - it's probably not the strip. There are a few things you can do, but I'm actually working on removing ours - it's a LOT of work but looks really cool when it's done. There are a couple threads around on it.
Other solutions include trying to tack it back up, but I didn't have much luck with any solutions I tried, such as using small screws with those caps, because then it'd just be hanging down between the screws.
If it's a different ceiling material, then disregard this post entirely.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-02-2015, 10:08 AM   #3
2000 30' Excella
It is the same material as you discribed. Did you try any kind of glue?
Old 07-02-2015, 10:17 AM   #4
1994 30' Excella
Mississauga , Ontario
I used solvent based contact cement. First I brushed the foam glued to the ceiling to remove any loose material. Then I saturated the foam with the contact cement. I applied a liberal coat to the back of the vinyl and let it all dry. Then I stuck them together and went over it with a 6 inch foam paint roller to ensure that it was all stuck together. Have been doing panels as they come down. Did the first one in the bedroom about three years ago and it is still just like when I did it. Only down side is that it is a little bumpy but not noticeable if you didn't know that I had done this.
Al
Al and Jean
TAC ON-3
Old 07-03-2015, 12:59 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I tried spray glue, no dice. The problem is that the backing separated from the vinyl, so there's not much to grab on to.
Old 07-03-2015, 02:29 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Use screws with white upholstery button coversion to tack it back up. Mine was done that way. I like the look.
CRH is offline   Reply With Quote
Old 07-04-2015, 04:55 AM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Oh, be careful with the screw solution- there are wires running up there somewhere.
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Ceiling Covering Falling Down RonH General Interior Topics 2 03-08-2011 02:37 PM
Falling padded ceiling panel 94 campster Interior Restoration Forum 5 03-31-2010 07:58 AM
falling ceiling , 96 Excella mauser1 General Interior Topics 5 05-04-2007 10:31 AM
69 Soverign (rear end falling down ???) leefields Repairing/Replacing Floor &/or Frame 8 10-22-2004 08:47 PM
