Old 03-08-2011, 01:42 PM   #1
1994 34' Limited
Ottawa , Ontario
Ceiling Covering Falling Down
I have a 94 34 Limited and the vinyl ceiling covering is de-lamanating in the cupboards and above the door. I have tried a 3M spray adhesive with very unsatisfactory results. How do I deal with this problem? Is it necessary to scrape the fuzzy layer off the inner metal surface? Do I really have to use a lot of glue?
Any assistance would be appreciated.
Ron
RonH is offline   Reply With Quote
Old 03-08-2011, 02:13 PM   #2
1994 30' Excella
Mississauga , Ontario
Hi Ron,
Do a search for this problem. There is a lot of info available.
There is no easy fix.
Mines a 94 and so far it has stayed up but it will fail.
AL
Al and Jean
TAC ON-3
Old 03-08-2011, 02:37 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
There isn't any "glue" fix that isn't cost/labor intensive. We had the ceiling fall in our '97 due to adhesive failure (due to EPA regs the glue used then fails at 95f). The past Pres of the Georgia Unit, Warren Fore, has templates to screw the ceiling back up with a pattern which makes it look almost quilted. It looks good, is affordable, and permanent. I realize you are in Canada, but he goes to a lot of the rallys and other events. I don't think he is on Airforums, but you can reach him through the Top of Georgia website.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
inside ceiling rivets lsrart1 Ribs, Skins & Rivets 1 01-17-2011 05:53 PM
Loose interior ceiling Bandits Ribs, Skins & Rivets 5 01-12-2011 05:05 PM
Hole in ceiling Brianv512 General Repair Forum 2 01-08-2011 06:24 PM
