Old 08-04-2014, 07:45 PM   #1
1975 29' Ambassador
Fort Wayne , Indiana
Ceiling
I need ideas for the ceiling and what material people are using to remodel with.
I really appreciate everyones help!!!!
tweetie1966 is offline   Reply With Quote
Old 08-04-2014, 07:50 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I used wood.
Name:	ImageUploadedByAirstream Forums1407203444.816030.jpg
Old 08-05-2014, 05:28 AM   #3
1975 29' Ambassador
Is there a # I can reach you at PLEASE!!
Tammie
Old 08-05-2014, 08:20 AM   #4
1975 29' Ambassador
Is there a # I can reach at. That is exactly what I am looking for!!
Tammie
Old 08-05-2014, 11:09 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Honestly I am not much for talking over the phone, but I can talk you through how we did what we did over this forum.
Old 08-05-2014, 12:32 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Ceiling
However, if you would like to have this done,,,,
I will send you a PM with my phone number.
I wouldn't mind doing a professional build for a customer. Building my wife's Airstream was the most fun and rewarding project I have ever done. Click image for larger version
Name:	ImageUploadedByAirstream Forums1407263560.798166.jpg
I learned enough on this build that I know exactly how I would attack the next build, what I would do the same and what I would do different.
Old 08-05-2014, 12:36 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Ceiling
Name:	ImageUploadedByAirstream Forums1407263720.043094.jpg
ID:	218336Click image for larger version
Name:	ImageUploadedByAirstream Forums1407263741.647683.jpg
A couple more pictures.
The wood goes on the walls and ceiling easy enough. We used 1/4" birch plywood lain against and screwed to the aluminum skin.
When I do another I think I would try to use 1/8" to see how it might work. The wood is not only attractive, it seems to help slow heat transfer in and out of the trailer.
The end cap was a little challenging, lots of measuring, cutting, and trimming to make everything fit nice and tight.
The trim hides the joint lines, the exposed screws on the trim makes everything quick and easy.
This trailer was my first carpentry experience.
Old 08-06-2014, 11:57 AM   #8
1975 29' Ambassador
Yes could you pm me your number. Thanks
Old 08-06-2014, 02:02 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1407355316.383919.jpg
ID:	218442Click image for larger version
Name:	ImageUploadedByAirstream Forums1407355331.339902.jpg
My trailer in the shop.
plastic ceiling panels art Upholstery, Blinds, Walls & Interior Finishes 10 01-12-2008 12:18 PM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
new furance or ceiling airconditioner with heat? striker Mechanics Corner - Engines, Transmission & More... 5 01-26-2003 10:03 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
