Old 07-13-2018, 09:29 AM   #1
1995 21' Sovereign
Petaluma , California
Carbon Monoxide detector displaying 29
Hello,
We have a kidde dual CO/explosive gas detector in our AS. This morning I checked the detector history and it shows at some point in the past few days, it hit 29, which Iím assuming is 29 ppm. It is currently reading 0.
From reading the kidde manual, it says the alarm wonít even go off unless itís at 50 ppm for 3 straight hours.
Is it normal to have a small amount of CO? The only thing we are using that uses gas is our stove burner, fridge and water heater, but these are all used infrequently as weíve had power hookups.
cgseanp is offline   Reply With Quote
Old 07-13-2018, 09:54 PM   #2
2016 19' Flying Cloud
Portland , Oregon
I've run into similar issues. Dealer changed out the propane regulator as they noted the water heater not burning clean.
Even since then the CO levels bounce up and down when we use the water heater, furnace and the fridge is on propane.
I've not tracked down any leaks from the exhaust of the appliances to the cabin but I suspect that fumes may get sucked in at times.
We always ensure good ventilation using the fantastic fans to keep the air moving around.
My thread on our issue
Carbon Monoxide leak from water heater !!
http://www.airforums.com/forums/f287/carbon-monoxide-leak-from-water-heater-165029.html
Snowy is offline   Reply With Quote
Old 07-14-2018, 04:04 PM   #3
1995 21' Sovereign
Thanks for reply. I recently changed my propane regulator to a camco auto changeover. Maybe I should verify itís all hooked up good
Combination Carbon Monoxide and Smoke Detector Recall PaulnGina Off Topic Forum 4 02-14-2015 08:32 PM
Carbon monoxide detector/alarm replacement Alphonse General Repair Forum 6 02-04-2013 06:43 AM
Carbon Monoxide Detector and strange smell frscott Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-19-2009 09:22 AM
Carbon Monoxide Detector Silver Threads LP Gas, Piping, Tanks & Regulators 29 06-20-2007 12:24 AM
Carbon monoxide detector...mystery story drcharles2 General Interior Topics 9 11-21-2005 02:50 PM
