Old 05-20-2011, 08:44 PM   #1
1971 27' Overlander
Hillsboro , Texas
Can you paint the Tambours?
We have a 71 Overlander with the dark paneling, the tambours work well enough but the color is not my best choice...has anyone painted them? If you have how have they worked after.
flamingo1 is offline   Reply With Quote
Old 05-20-2011, 08:47 PM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I painted the tambours over the litchen and dinette in my 82 ltd. No problems so far. I taped up good and sprayed them.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 05-20-2011, 08:48 PM   #3
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I'm not really sure what a tambour is, but welcome to the forums and congratulations on your first post.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-21-2011, 05:47 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Absolutely...we did our front tambour and it turned out great. Just tape up to avoid overspray...we used Krylon Plastic paint from Walmart...no runs, no drips, no errors!
ID:	130315   Click image for larger version
Name:	Front Shelf 2 jpeg.jpg
Roadrunner is offline   Reply With Quote
Old 05-21-2011, 07:52 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I would spray, not brush, the paint on. There is a resource for different colored tambors, if you decide to change them out:
Curvwood Veneer - CurvTambour - Tambour Wallcovering Products - Curvwood fine Wood Veneer products, Wood Wallcovering, Tambour solid wood, veneer, metal tambour panels, Paperback veneer, DuraBack, Peel and Stick wood veneer, Wood on Wood veneer
Old 05-21-2011, 07:59 AM   #6
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
We've had good success with painting our tambours using Krylon Plastic paint as well. This will be our 4th camping season with the painted tambours and the paint is holding up very nicely and the tambours still work.
maccamper
maccamper is offline   Reply With Quote
Old 05-21-2011, 11:27 AM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Ditto what others have said. We used Krylon (IIRC) for plastic spray, on the front locker like Roadrunner and Valspar on the bath tambours. Both are holding up well after a couple of years.
www.nesa.org
Air No. 6427
Sunburn or spray paint? Tabasco Cleaning, Stripping & Polishing 10 05-24-2012 10:01 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 01:19 PM
Airstream 22' New Floors, Head, Tires, Brakes, Paint. eBay Watch Airstreams on eBay 0 04-29-2011 11:20 AM
New Member - more than the paint is not yet dry amuse Member Introductions 1 04-13-2011 08:07 AM
GT Paint Job IronGiant Upholstery, Blinds, Walls & Interior Finishes 0 01-11-2011 10:17 PM
