Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-05-2010, 07:34 PM   #1
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Can I remove our table??
We have a 2010 Sport 22 FB and I would like to be able to remove the table while watching TV, is that possible?
Gary
Castaway is offline   Reply With Quote
Old 09-05-2010, 08:00 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I had to read this over and over... I figure if you've got the good lord on your side, then anything is possible!
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 09-07-2010, 09:24 PM   #3
Castaway's Avatar
Celina , Ohio
44 reads and no answer? I guess that it is not possible
Gary
Old 09-08-2010, 04:55 AM   #4
Mantua , Ohio
If it is like most tables, slide out the two top supports like you are going to make it into a bed, then lift the u shaped bracket away from its support and the table should be free. zz
Old 09-08-2010, 06:25 AM   #5
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Can you show us a photo? As long as you own it or at least keep making the payments you can do anything you want with the table.
Im sure there is a way to remove it. Without seeing it its hard to say how
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
remove table dhe9 1997 - 2004 Bambi 2 04-21-2007 08:15 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
Anyone need a table.... Jim Jarzabek Cabinets, Counter Tops & Furnishings 0 02-23-2006 04:29 PM
