Old 03-12-2013, 11:25 AM   #1
1969 18' Caravel
Augusta , Georgia
Can I paint the ugly bathroom sink?
So my 69 caravel has the worst looking bathroom sink. I hate to replace it because of the design. Any chance someone has painted their sink with spray paint made for plastics? Did it come off after use? Any other ideas?
Caroline
1969 Caravel "Sylvie"
moderninthesouth.blogspot.com
Modern South is offline   Reply With Quote
Old 03-12-2013, 11:39 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I used Tough As Tile Epoxy paint. A bit hard to work with and the fumes are really bad. Use lots of venting. Did 2 years ago and the results are great. Also used it on our old bathtub in our house with the same great results.
Tough As Tile Epoxy Finish, Brush On, White
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-12-2013, 01:23 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I am going to be doing this in a few days and am planning on using a marine-grade two-part linear polyurethane paint, which I'm going to brush on. The vapors are toxic and the stuff is expensive and difficult to work with but done properly the results look great and are extremely durable. The product I'm looking at is Awlgrip, which West Marine has in stock.
Old 03-12-2013, 01:24 PM   #4
1970 27' Overlander
Connelly Springs , North Carolina
I used the plastic spray paint but haven't road tested yet. Looks great though. We sprayed the whole area. If it does scratch I figure its easy to reapply.
Mhkricket is offline   Reply With Quote
Old 03-12-2013, 01:28 PM   #5
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
I didn't know awlgrip was brushable. Did west tell you that or a boat painter?
tarnished is offline   Reply With Quote
Old 03-12-2013, 01:34 PM   #6
1970 27' Overlander
Considered brushing on a clearcoat afterwards to ensure that it would not scratch so easily.
Old 03-12-2013, 01:40 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
West. You have to use a different reducer than for the spray system, and you have to use natural bristle brushes -- plastic bristles will dissolve.
Awlgrip's web site has details too.
Old 03-12-2013, 02:00 PM   #8
Topping , Virginia
OK Jammer, sounds good thanks for the info.
Paul
Old 03-12-2013, 02:56 PM   #9
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
I'll add this epoxy project to my to do list. I have used the spray paint for plastics on other projects. Not very impressive. Good coverage but scratched easily.
Must maintain at 72 degrees. That's going to be the trick. Maybe a May or June project...
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-12-2013, 03:16 PM   #10
1977 Argosy 24
Milltown , Wisconsin
Make sure to rough up the area with a red scotch pad first, so it will not peel later on.
ventport is offline   Reply With Quote
Old 03-12-2013, 03:31 PM   #11
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
-->This<-- is what I used to do the tub and black tank on my '63 Globetrotter. It goes on with a foam brush and the results are flawless. It's called Mr. Tubby
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-12-2013, 03:36 PM   #12
1981 31' Excella II
New Market , Alabama
Is your sink fiberglass or ABS? I wonder if it would melt ABS?
Perry
Old 03-12-2013, 04:10 PM   #13
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Plastics?
Perry
The directions say it is o.k. on plastics. I think I might give it a try. I especially like the color selection.
mopariac is offline   Reply With Quote
Old 03-12-2013, 05:22 PM   #14
eljay's Avatar
1968 24' Tradewind
OOOOOH colors!
Eljay
