Old 03-12-2013, 06:26 PM   #15
1969 18' Caravel
Augusta , Georgia
Thanks for all the advice. I am going to wait and try the epoxy later this spring. I'm just gonna give it a good scrubbing for now and focus on the majors. If someone discovers an easy spray on solution that lasts let me know!
Caroline
1969 Caravel "Sylvie"
moderninthesouth.blogspot.com
Modern South is offline   Reply With Quote
Old 03-12-2013, 07:57 PM   #16
1986 31' Sovereign
Miami , Florida
I used a five dollar can of gloss white Krylon Fusion. Worked fine.
Mike
n2916s is online now   Reply With Quote
Old 03-12-2013, 08:17 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Mike
I have used Krylon Fusion for various other projects. I think it's fundamentally a good product that has its place. It's perfect for painting the doorbell cover, or the 4" round plastic furnace duct outlets.
But it doesn't have the durability for something like a sink, which is going to have to be scrubbed clean from time to time.
Old 03-13-2013, 06:15 AM   #18
1984 31' Sovereign
charleton , Illinois
I asked at Sherwan Williams paint store for advice. They recomended a specific type of primer and top coat. I followed their advice and had great results. These products are not avalible in spray cans but I used an air gun. Two years later it still looks great.
jerry d is offline   Reply With Quote
Old 03-13-2013, 06:42 AM   #19
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
perryg114- the bathroom (sink, tub & toilet top) in our 65 Safari is fiberglass (plastic). The "Tough As Tile" recommends maintaining temps of 72+ for a few days - curing time. We did it in Feb. (Michigan) and used an electric heater in the bathroom with the door closed. Maintained 75 for 4 days.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-14-2013, 06:48 AM   #20
1969 18' Caravel
Augusta , Georgia
Mike - how long ago did you use the Krylon and have you scrubbed the sink?
Caroline
Old 06-24-2013, 01:45 PM   #21
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
I would love to add to this topic as I am working on this now and have had horrible results with tons of work. I started by removing my tub, back splash and sink surround. They all received new fiberglass backing for any cracks and bondo up front to smooth the surface. Each was sanding with 120 grit and then 220 grit to perfection.
Then the hell began...
I decided to try POR-15 Whitecote because everyone around here raves of the regular POR-15 and it's durability. I also read another thread from and Argosy owner who used POR-15 Whitecote and was very happy with the results.
We applied the Whitecote and immediately noticed that this was going to be bad, but we thought maybe it will self level over time. It did to some degree but what we were left with after the 72 hour curing time was much less than desirable. There was serious amounts of orange peel and pinholing throughout the surface as well as dripping down any vertical face. I thought that my GF just applied too heavy a coat on the tub so I applied the next round. It didn't matter, Even light coats were subject to some dripping. Anyway, I highly recommend AGAINST this product unless you want to spend the next 2 week sanding...
Now that I have the pieces sanded back down to the plastic, I have repainted with XIM Plastic Primer. I used spray cans. I worked great. Bonds great to the bondo and plastic surface. I applied two coats and sanded smooth. My next step is going to be the Tough As Tile from Homax.
I will update this thread after and let you know my results. I am crossing my fingers because I don't think I can handle any more serious sanding at this point.
crabbey1 is offline   Reply With Quote
Old 06-25-2013, 10:39 AM   #22
1981 31' Excella II
New Market , Alabama
I am thinking about trying some upolstry paint that the local car paint store sells. I have used it before with good results. I painted the dash in the excursion with it and it has sat there for 2 yrs in the sun without pealing. I also used it to paint the window frames. You can get lots of colors in this stuff and it is in a can and it is made to paint plastic metal and even fabric. I don't know about the durability of the stuff but it seems pretty good. I have a removable piece by the toilet that I may experiment with and see how it does on that.
Perry
Old 06-27-2013, 04:37 PM   #23
crabbey1's Avatar
1976 Argosy 22
Images: 33
UPDATE: After sanding with 220, spraying 2 coats of XIM plastic primer and sanding with 220 again, I sprayed 2 coats of Homax Tough as Tile. It looks awesome! Sprayed on nice and smooth. Now I have to wait 72 hours for it yo cure before I can do the 800 sanding, 1500 sanding and finally a buffing wax. I will post pics when completed.
Old 01-24-2015, 06:33 PM   #24
Mixter's Avatar
1976 27' Overlander
Hey Crabbey- how did this end up? I assume yours is the same plastic sink and tub as my '76 Overlander? Curious how the epoxy works on the flexible surface.
Any pics or updated info is appreciated!
Mic
Mixter is offline   Reply With Quote
