Nothing back there
If you look around the outside edge of the endcap, you will see the rivets that are holding it in place. Other than those rivets, there is nothing else holding it up there, and the only thing behind it is insulation. There are not even any cross-members for support in mine not sure if yours would be the same.)
I had thought about setting my small LCD up as a flip down just under the shelving in the endcap but adding supports between the endcap and the fiberglass shelf shell itself and bolting the hardware into that.
I ended up changing my mind on layout so now it isn't going there, but that would work. My endcap is actually two pieces the molded shell for the shelf and the endcap itself. I figured I could add support between the two where the tv would hang and that would hold it there. This involves removing the endcap though.
