Old 07-19-2013, 07:35 PM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
cable TV switch
I own a 1976 Tradewind. There are 3 outlet boxes under the window on the driver's side of the bedroom. The first one has a switch, coaxial connection, and a DC outlet. I guess it's for a tv, but I can't find the other end of the cable. Does anyone know exactly what this is and how it's supposed to work?
terrencecolp is offline   Reply With Quote
Old 07-19-2013, 07:59 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I have a 72 Tradewind 25'. 12v TV powered by DC outlet (I think Walmart still sells them), coax cable for TV connects to coax connection which terminates at your antenna. I tore all mine out...going with an HD air antenna and just one TV in the front. Anything else, I can get on my iPad and wifi connection.
arktos55343 is offline   Reply With Quote
Old 07-19-2013, 08:04 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
cable tv switch
Greetings terrencecolp!
Welcome to the Forums and the world of Vintage Airstreams!
What you have may have been added by a previous owner as a TV cable connection wasn't available on the 1976 Airstreams. On the other hand, you may be looking at the original outlet for a television antenna with 12-volt DC signal booster (switch) near coaxial connection with 12-volt-DC outlet. In its original configuration, your Airstream could have had an optional roof mounted antenna (usually mounted over the open area in front of the lounge at the front of the coach). Since 300 ohm flat twin-lead television wire would likely have still been utilized in 1976, there may be a coax to flat twin lead wire at one end or the other of your coax.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-21-2013, 07:01 PM   #4
1976 25' Tradewind
Tulsa , Oklahoma
Thanks everyone. My question was answered. I see coaxial cable on my roof and an antenna booster certainly makes sense.
2011 International EXT cable hookup not working alozier Audio, Video & TV 6 10-20-2011 03:42 PM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 10:03 PM
Useless Breakaway Cable Routing overlander63 Brakes & Brake Controllers 40 07-02-2011 11:22 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
