Old 10-10-2014, 04:54 PM   #1
1977 31' Sovereign
Walloon Lake , Michigan
Cabinet trim
I have a 77 Sovereign and would like to replace the vinyl and plastic trim that fits in the channels that form the base cabinets. Also there is a long plastic piece that is border between the walls an ceiling. It has yellowed and cracked. It slides into a aluminum track. The upper cabinets though out the coach have trim pieces that slide into a aluminum channel. The trim pieces appear to be about 1 inch wide although some of the vertical pieces on the lowers are 1-1/4. Does anyone know of a sorce for this material.
wallooner is offline   Reply With Quote
Old 10-12-2014, 07:31 AM   #2
1954 25' Cruiser
1975 25' Tradewind
1967 22' Safari
1975 26' Argosy 26
Altona , Manitoba
Steve at Vintage Trailer Supply can help you out.
Vinyl Bath Insert
HowardFS is offline   Reply With Quote
Old 10-12-2014, 09:03 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Hope this thread turns up what you are looking for. This sounds like the correct insert.
http://odmrv.com/catalog/index.php?m...oducts_id=1109
For my Safari, I'm looking for the plastic piece at the transition of the horizontal kitchen countertop to the vertical wall behind.
Alan
Old 10-12-2014, 10:03 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Formica might work.
What is a "base cabinet" and "upper cabinets" Photos would help
Looking for cabinet aluminum channel/trim sources... BellaLuna Cabinets, Counter Tops & Furnishings 5 11-21-2012 04:11 PM
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
Sliding Cabinet Trim Eyeketch Cabinets, Counter Tops & Furnishings 3 06-12-2006 04:41 PM
Overhead Cabinet Trim thombrad General Interior Topics 0 08-11-2004 06:47 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
