Old 08-15-2011, 02:57 PM   #85
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
I need the other kind...
Erik,
I have some bunk bed hardware for the kind of bunk bed you're looking for. I have two wall brackets and one keyhole suspension plate. If I can find the bunk bed hardware that I'm looking for then I won't need mine.
I need the older kind of bunk bed hardware, for a wood bunk bed. I need two metal pieces that attach to the wall. Like this:
I also need a pair of latches that keep the bunk in an upright position during the day. Like this:
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 08-19-2011, 09:24 AM   #86
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
Thanks, Lynette! I tried to PM you, but I'm not trusted yet. Also didn't want to hijack this whole thread for my personal search. That said... here is the classified ad I posted for bunk hardware: Airstream Foldable Bunkbed Frames / Hardware - Airstream Trailer Classifieds - Airstreams Trailers For Sale
Just took delivery of "Ohana", our new 1974 Ambassador last night. Almost entirely original save for a fresh new floor and upholstery. Pics coming!
Erik Olson is offline   Reply With Quote
Old 08-30-2011, 07:33 AM   #87
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Decided to build out the bunk frames from 1" OD schedule 40 aluminum tubing and Hollaender speedrail corners / support brackets with plywood support (as Airstream did in 74). It's going to be a bit spendy, but I'm fully committed. Anodized aluminum all.
  • $92 1" Tubing (Freedom Metal, CLT)
    • 2) 6' cuts
    • 4) 3' cuts
  • $10 Stainless Ball Shank Swage Ends (Fastenal)
  • $0 Shielded Airplane Cable (Garage item)
  • $153 Hollaender (Barbizon Lighting)
    • 4) SR31 Corners
    • 6) SR17M1 Eye Bracket
    • 4) SR27M Double Eye Bracket (ply support / wire rope receiver)
    • 4) SR411 Articulated Wall Bracket
Old 08-30-2011, 08:13 AM   #88
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
[*]$92 1" Tubing (Freedom Metal, CLT)
[*]2) 6' cuts[*]4) 3' cuts
[*]$10 Stainless Ball Shank Swage Ends (Fastenal)[*]$0 Shielded Airplane Cable (Garage item)[*]$153 Hollaender (Barbizon Lighting)
[*]4) SR31 Corners[*]6) SR17M1 Eye Bracket[*]4) SR27M Double Eye Bracket (ply support / wire rope receiver)[*]4) SR411 Articulated Wall Bracket
Pictures? Pretty please? :-)
Phrunes is offline   Reply With Quote
Old 08-30-2011, 10:30 AM   #89
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
I've been really bad about pictures... so far! We are doing the Ambassador shake-down run this weekend. Lots of photos to follow. I'm getting the aluminum tubing and swage shank ball hardware tomorrow - bunk beds are imminent!
BTW, thanks to the members who put those impossible-to-find round keyhole brackets into our hands. The last pair are going out in the mail today!
Old 08-30-2011, 02:31 PM   #90
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Changed some vendors, but spec is the same...
  • $70 1" OD 6061 .0125 Tubing (MetalsDepot.com)
    • 2) 6' cuts
    • 4) 3' cuts
  • $10 Stainless Ball Shank Swage Ends (Certex)
    • 4) SR31 Corners
Old 08-30-2011, 03:50 PM   #91
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Can't wait to see pictures! You can see photos of our custom bunks if you click on my pictures.
Skatiero is offline   Reply With Quote
Old 09-01-2011, 07:38 AM   #92
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
This poor photo is of the shank ball terminator swaged onto the 1/8" vinyl-coated galvanized cable. Though it looks like the cable is wider than the fitting, it is the vinyl jacket magnifying the cable inside that creates the illusion. The working load limit of this cable, and the crimped terminator, is 345lbs.
These play into the Airstream keyhole suspension plates, which were riveted into the ceiling panels. I may instead attach these plates to the bulkhead walls for added strength.
At the other end, there will be a ferruled loop over the vinyl, which will protect the kids from stray steel ends.
Old 09-01-2011, 11:40 AM   #93
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
More bits showed up today. The Hollaender fittings actually came in as 1" ID / 1.25OD, so I'm back to 1" ID 6063 aluminum schedule 40. Ah well, beefier is better.
Old 04-05-2013, 05:36 PM   #94
1964 22' Safari
Denver , Colorado
Does anyone still have these brackets????
santafejoe is offline   Reply With Quote
Old 04-05-2013, 06:51 PM   #95
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Try a marine supply. The might not have the exact ones but will have similar
Lumatic is online now   Reply With Quote
Old 04-05-2013, 08:20 PM   #96
We have a few of the originals left.
Old 04-14-2013, 03:59 PM   #97
1969 18' Caravel
Augusta , Georgia
When you all get one of these bunks up and running I would love to see a picture. Our little Caravel is pretty small, still okay for our little one's but the day will come when a bunk would be great! It may not be possible in our little trailer, but still can't wait to see what you come up with!
Caroline
1969 Caravel "Sylvie"
moderninthesouth.blogspot.com
Modern South is offline   Reply With Quote
Old 04-15-2013, 11:30 AM   #98
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
I have Ohana home today, so I'll post some pictures up later when I get in. The key thing we ran up against on this project is finding a rigid, lightweight platform to put a mattress on. The original was a collapsible aluminum frame with webbing, which is, as far as I can tell, completely unobtainable in the 21st century.
After some experimentation with various plywoods and other materials, we settled on 30" hollow-core 30" doors from Lowes. The doors are incredibly light, rigid and have a perimeter frame to take carriage bolts from the Hollaender fittings. The doors are standard dimension, which means we had to take a panel saw to one for the bunk / berth that is behind the oven bulkhead.
The swaged airplane cables go to four of the Airstream keyhole plates (Andy used to have these), which are made to the ceiling with 1/8" x 1/2" rivets.
Mattresses were sourced from Ikea and fit perfectly.
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Bunk Bed pmacdavid All Argosy Trailers 8 01-28-2011 07:41 PM
Any one know where to find pictures of the bunk bed attachments mareinmn General Interior Topics 15 08-28-2006 10:48 AM
long bed vs short bed towing 8400 lbs. longears Tow Vehicles 24 08-09-2004 03:32 PM
Bunk bed aviontt Cabinets, Counter Tops & Furnishings 6 09-02-2003 02:41 PM
